Sewell prewired LED headlights
I didn't know the sewell one was prewired because i purchased mine from sewell, but I still had to get them wired to get thr DRL running.
Found this on CL
http://sfbay.craigslist.org/pen/pts/5705967030.html
Found this on CL
I think sewell was prewired to just plug and play except for the DRL running. You just had to turn off or one turn for just the led to come on. I think that ad for light is user metaleckz on here. I messaged him but not sure if that one is prewired or if he is willing to ship it.
Sewell will sell you any side you want to purchase. Worth the call. You still get the discount we had before.
It seems I can do it this way with the 2011-2013 oem headlights to work on my 2010
"So I went with what "thinktwice" originally did..
I snipped the thinner solid red wire, then tapped it into the Black & White wire underneath it..
Then I changed the pin location of the Green Wire to the empty spot... Done.!!" solid green wire to the default third empty slot next to the white and black wire striped wire.
or
https://www.clublexus.com/forums/is-...0-circuit.html
or
