How To Change Out DRL Bulb??
I want to change out the ugly old yellow bulbs in the DRL lenses, how do I get access to it, and what bulbs are available? I'm thinking LED. I don't want to change out the whole headlight assembly even though I see aftermarket ones on ebay (I may get them later).
The DRL is not a separate bulb, it is your high beam bulb running at 20% power. Changing it to an LED will effectively kill your high beams. I didn't want to lose my high beams so I just disabled it because I hated the dingy yellow look of it as well.
So we can disable the DRL and still use the high beams?? I couldn't find a clear thread on how to do that,,, but that might be the noob in me rearing its head.... Help??
http://www.xenondepot.com/9005-nokya...-p/nok9005.htm
Arctic whites are what I have - they look a little bit creamy white in daylight and dawn/ dusk will appear crystal white
With these bulbs you keep your Hi-beam option as well. The blue coating on the bulb gives off a cool look from the front of the car when the low beam and parking light are on as well as the parking light shines through the blue bulb
Just changed my DRL last week.
You need the decoder too,so the led's don't flicker, bought these from ijdmtoy and they work great
http://store.ijdmtoy.com/60-SMD-9005...t-p/40-440.htm
Just remove the plastic covers and airbox and you can access the high beam bulb.
Yes, you can simply disable the DRL and still have high beams. You need Techstream stream to do it.
There's really only 3 options here:
1) Change nothing, keep the yellow looking DRL, keep your high beam
2) Get LED high beam bulbs, bright white DRL, lose your high beam
3) Disable DRL on Techstream, lose the yellow DRL and keep functioning high beams
Then your high beam won't work either. It's the same bulb.
