IS250 opinions
Old 07-18-16, 11:57 AM
leg3ndary
leg3ndary's Avatar
Originally Posted by Blue300is
Thinking about buying one... However do you guys think 145k miles is to much? For 11k.... Possibly able to rework them down. Comes wit extra set of rims for the winter with blizzaks. All the tools with spare. Or there's another one with 101k without anything extra for 9k.
I wouldn't buy a IS 250. If you're budget is 11K, you should buy a used Civic with 30K miles on it. You will get your money's worth for sure, and you will have a dependable car.
If you can expand your budget, go for an IS 350..
Old 07-18-16, 01:45 PM
top5
top5's Avatar
Is the car a CPO?
Old 07-18-16, 02:02 PM
leg3ndary
leg3ndary's Avatar
Originally Posted by davyjordi
late 2010 models and on should have minimal issues with carbon build up due to an engine revision/correction by lexus/toyota.
The modification that they made was changing up the piston rings in order to reduce the carbon buildup from blowby into the crankcase. It will deter major issues in the crank case, which will lead to a dead engine, but it does nothing to prevent the carbon caking onto the valves intake/exhaust valves.
All DI engines (majority of manufacturers are forced in this direction due to EPA) have this issue, it's not limited to Lexus, but DI engines should be a no-go no matter who has built it. The only type of DI engine that works is the dual injection system found in the 3.5 liter engines..
https://en.wikipedia.org/wiki/Toyota_GR_engine
Old 07-18-16, 02:51 PM
davyjordi
davyjordi's Avatar
what are the implications of carbon build up on the intake/exhaust valves? i honestly don't know and i own two 3IS 250s
Old 07-18-16, 03:56 PM
leg3ndary
leg3ndary's Avatar
This is a good write up on the topic
http://www.thetruthaboutcars.com/2012/05/ask-an-engineer-gdi-problems-in-a-nutshell/
Old 07-18-16, 04:07 PM
davyjordi
davyjordi's Avatar
http://www.thetruthaboutcars.com/201...in-a-nutshell/
thank you!
Kapitanemo
03-20-17 01:00 PM
HartFB
01-13-17 12:04 PM
P128sniper
04-11-13 08:54 AM
cherishzm
01-09-13 03:19 PM
TheRusski
08-15-12 08:14 PM
Quick Reply: IS250 opinions
