IS 250 breaks messed up.
Old 06-10-16, 07:17 PM
Leehuss
Leehuss's Avatar
Default IS 250 breaks messed up.
I have a 2006 Lexus IS 250 awd. I changed my back breaks today, and now my breaks are grinding on the rotor. I tried driving it 500 feet to see if it would help. Any suggestions?
Old 06-10-16, 07:38 PM
A1cntrler
A1cntrler's Avatar
Did you press the piston back into the caliper before you put on the new brake pads? Not sure how you could have done it without doing that step, but just making sure you did that. It's possible if you pressed them back in and didn't do it exactly straight the piston may have scratched the cylinder and it's now bound up in there not releasing the pressure back off the rotor.
Old 06-10-16, 08:11 PM
Gville350
Gville350's Avatar
Seized calipers. So now with the new pads with the seized calipers cannot pull the pads away from the rotors enough not to touch them. Ask me how I know.
Old 06-10-16, 08:14 PM
A1cntrler
A1cntrler's Avatar
If this is the case and they really have only driven it 500 ft, they may be able to use the new pads/rotors when they replace the calipers.
This happened on my truck (rears) and I didn't notice it until I had driven about 30 miles. When I stopped there was some smokin' hot brakes/rotors. Ended up with new calipers/rotors/pads.
Old 06-10-16, 09:41 PM
Leehuss
Leehuss's Avatar
Yes I pressed the piston back as far as it would go. They were still really snug when I put everything back together. I Though it could be a seized caliper but I just changed the breaks. they both messed up at the same time. I figured only one would have went out. Thanks for all the help. If you can think of anything else just let me know.
Old 06-10-16, 11:02 PM
abounly
abounly's Avatar
i'm sorry but its "brakes". Check the surface of your rotors.
Old 06-11-16, 04:43 PM
yada
yada's Avatar
I seized up the caliper on my 02 lancer (non evo) my brakes were metal to metal for quite awhile because i couldnt afford new brakes yet. Kept driving the car until 1 day i pulled up to my house and my pedal went to the floor without car stopping. I pressed the pedal again and my car then stopped, my friend who was washing his car in the driveway came down to the curb because he saw something falloff my car and it was my brake pad
When i tried changing that sides pads i couldnt push the piston back into The caliper.
Old 06-11-16, 07:57 PM
Gville350
Gville350's Avatar
^Hey, I had '03 OZ Rally Edition Lancer back in the day.
Old 06-11-16, 08:22 PM
yada
yada's Avatar
I still have my car. Its beat to **** but its been reliable. 170000 miles. Only maintenace had to replace the ignition switch, radiator, tie rods, shocks. Im having issues shifting into gears and my ac units not working. Been a great car.
cnguyen408
Suspension and Brakes
02-05-13 11:36 AM
Snyperifle
08-15-12 05:53 PM
cowsgomoo
04-25-12 01:17 PM
gs3Nic
07-26-10 03:27 PM
MTElnb1
02-17-08 02:19 PM
Quick Reply: IS 250 breaks messed up.
