Removal of the panels below the steering wheel?
Old 06-07-16, 11:55 PM
Ling2IS
Ling2IS's Avatar
Default Removal of the panels below the steering wheel?
Anybody have a DIY/video on how to remove ALL the panels below the steering wheel?
I've managed to pull of two, but the second to bottom last panel doesn't seem to want to budge.
Old 06-08-16, 08:10 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
That's the airbag, you need to remove the entire assembly (four 10mm bolts). If you want to actually take it out of the car make sure you disconnect the battery for at least 60 seconds before unplugging it. Also be careful with the double-lock connector, they are not typically sold separately.
Jeff
Old 06-10-16, 10:40 AM
sebyaris
sebyaris's Avatar
in fact there are 3 bolds . 2 of them you can easily see near the steearing and 1 on the bottom of the lower pannel . I had to replace my clock spring and I faced the same problem .
Batmobile
10-27-22 01:57 PM
khizr23
01-07-19 02:04 PM
Hiep25
ES - 5th Gen (2007-2012)
06-03-18 02:18 PM
Mark
07-09-14 05:03 PM
badx33
11-11-09 10:04 AM
Quick Reply: Removal of the panels below the steering wheel?
