Car pulls slightly to the right
In your case i don't think its your TIRES, something to do with Inner/outer Tie rods and ball joint, 1st thing to do is rotate your tires, take the right front wheel put it to the left same at the REAR. if a Radial pulled occur you should feel it on each wheel.
He said it's either alignment and if alignment doesn't fix it he said it's radial tire pull...so I tried to alignment hoping it would fix it.. I'll ask dealership on Tuesday, how much would lexus charge normally for figuring out what the issue be, just inspecting it?
You said it already, if radial pull it should have pulled when you 1st installed ? but anyways who knows, it might be radial, try rotate your tire see if it pull on the other side, your tires has warranty, you better do it now.
Looks like a tire roll... Have you tried to go in the left lane on the freeway and check if it pulls left? A right pull is usually ''normal'' since there is a slight slope (1 to 5 degrees) on every roads to evacuate water, but it shouldn't be that noticeable.
My car pulls left or right depending on these slopes... It got worst when I installed my summer tires so I'm guessing I need a new set of tires. Alignment was done a few months ago so I know this is not my issue... May-be it's your case as well.
I'm starting to think it's just the power steering is super sensitive especially with these tires, pulls right on normal roads and on the left most Lane on Highway it actually pulled left.. Didn't notice this on my winter tires.. Can it actually be juat the slope of the road causing the pull? I blame electric power steering if so..
To test the pulls, he should find a wide parking lot without any road crown, drive 15mile/p and let go the steering see which direction it pulls, or on freeway drive 40-50 mile/p shift N and let go the wheel but do it safely when no cars around. My bet is his inner tie rod end, alignment shop nowadays don't care about our cars, they align they charge $ and done, you come back you pay more, that's business !
We called that a "Road Crown" yep engineer designed road inclined to prevent road flood but bro, is250 350 should not have that on the right lane. he should not feel RIGHT PULLED on right lane except Fast Left Lane for our Lexus it very very slight pull won't be noticed for most of drivers unless you really concentrate on the steering.
Mine doesn't pull at any directions when the surface is completely flat. Works like a charm!
When there's a slope, it pulls either left or right. It didn't do that with my winter tires on so I know this is not a mechanical issue (tie rods, alignments, etc. are fine). Must be the tires then.
You are probably right!
Small updated. Just pulled up to lexus dealer for oil change and free alignment check. They have this machine on the ground when u pull in that quickly checks ur alignment and shows it on the graph and it says I definitely need one. It costs $179 bucks here so I think I'm going to get it but hope it fixes the issue. I told them to check tires first as well because I'm not paying another $180 on top of the $75 I already paid last week at local alignment shop which obviously didn't do ****... Im going to write then the most negative review possible. I'll update what happens when I get out of here.
Yea man with oil change I paid close to $250...uhhh, so update again.. Definitely drives a lot better now, is the pull totally gone, too early to tell yet haven't really driven it a lot yet but it definitely feels better and any pull that I have no I will have to blame on road sloap or maybe just tires.. Everything else checked out..
After driving more I can definitely say it's fixed... It'll pull here and there but that's just from bumps and electronic power steering taking over.. I would stay away from local alignment shops!!!
