Washing the box and intake tube is most likely going to be fine as long as you let it dry completely before using it again, as for the filter just go buy a new one the OEM filters are not meant to be cleaned and used again from what I know.
i have aftermarket intake, just cleaning this one for sale, thank you lysis
It still pertains to what he said, The actual filter is meant for 1 time use. It should be discarded after use. Unless you have a different drop in filter that specifies it can be re used after cleaning.
The actual intake box and tube shouldn't be a problem though.
