Urethane Replica Wald Trunk Spoiler Paint not sticking
Old 04-13-16, 10:43 PM
drwafk
drwafk's Avatar
Default Urethane Replica Wald Trunk Spoiler Paint not sticking
I've searched these forums and google for a fair amount of time and am not finding my answer. Basically the paint wont stick to the bumper. I bought it from ebay FYI. Here are the steps I took. I've been testing the prep/paint on the inside of the bumper, havent doent he exterior side yet.
1. Washed the spoiler with Dawn dish soap and dried it thoroughly.
2. Sanded the spoiler with Scotch Brite scouring pads.
3. Wipe "plastic dust" with Isopropyl Alcohol.
4. Spray with Rustoleum Black Gloss.
This is where I run into the paint not sticking at all. I'm using light coats and its just beading up. Is it the paint I'm using? Do I need some sort of primer/undercoat?
Any help is greatly appreciated.
Attached Thumbnails Urethane Replica Wald Trunk Spoiler Paint not sticking-0414160018.jpg
Old 04-14-16, 12:50 AM
TopNotchIN
TopNotchIN's Avatar
Yes, you would need to use a primer. What you need to look for is a plastic primer. It's specifically made for urethane (or "plastic") parts and will be able handle the flexing/bending of the material. When body shops paint bumpers they use a special primer and clearcoat that has a "flex agent." This allows the urethane parts to naturally be flexible without causing the paint to spider or crack. Have you ever noticed some cars bumpers have cracked and peeling paint after a minor fender bender? That's usually because of poor or improper primer and clearcoat being used. Now that's not always the case, but is a good example. I hope this helps out.
Old 04-14-16, 06:46 AM
metaleckz
metaleckz's Avatar
http://www.tcpglobal.com/SEM-39131_5...B#.Vw-fHchHaJI
Old 04-14-16, 08:31 AM
Icy350
Icy350's Avatar
Sand it HEAVYILY with a Higher 280ish Grit paper first. Make sure you get all that nasty material off first. Then move on to a 380 Grit so smooth it out. Make sure there is no more top layer of that nasty Material.
Then you would move on to PAINT ADHESIVE.
Many people choose to skip this step but Idk why they would as it allows the coats of paint to PROPERLY adhere.
After that you would use a primer and paint as usual.
You should have no problems with paint not sticking as long as you sand and prep properly.
Gotta put in the extra work for getting cheaper materials.
Old 04-14-16, 08:52 AM
drwafk
drwafk's Avatar
Thank you, this is very insightful. So you're saying Plastic Primer, Paint, Clear got it. I'll report back once I try this out.
Thank you, this is perfect.
Ok so its Sand,Paint adhesive (after further looking its called promoter yes?), Primer, Black Gloss, Clear coat. Heres what I found:
Amazon.com: SEM 39863 Plastic Adhesion Promoter Aerosol - 14.8 oz.: Automotive Amazon.com: SEM 39863 Plastic Adhesion Promoter Aerosol - 14.8 oz.: Automotive
Then I use: Flexible Primer Surfacer, Superior Adhesion then paint, then, gloss. Think I got it. Thank you all.
Old 04-14-16, 01:08 PM
Gville350
Gville350's Avatar
FYI, there is plastic-specific paints from Duplicolor that don't require primer. Used a satin black of this same paint on my cowl cover with excellent results!
Old 04-14-16, 10:27 PM
drwafk
drwafk's Avatar
Thanks. Nice work on your cowl covers.
Old 04-15-16, 12:32 AM
whitecel
whitecel's Avatar
You are missing the the adhesion promoter followed by primer before painting. With raw plastic, it needs an adhesion promoter. Can use bulldog adhesion promoter. Pretty sure after that you can use 2k urethane primer. Just make sure it is compatible with the paint you are using.
Old 04-15-16, 08:35 AM
drwafk
drwafk's Avatar
Ok got it, Adhesion promoter, primer, paint, clear coat. I'll do this project this weekend and report back. Thanks for the help.
Old 04-16-16, 09:27 AM
Icy350
Icy350's Avatar
Im actually re painting my Wald Spoiler over the weekend as well. I will post results for your reference
Old 04-16-16, 10:19 AM
drwafk
drwafk's Avatar
Default Supplies
A couple of lessons learned to share. The products for this project are listed below as shown in the picture from left to right. Also if my wald replica spoiler in the background looks warped that's because it is. I'm hoping that by the time I get it painted and mounted, it'll look straight. I tested all these on the inside of the spoiler to make sure I didnt make a mistake.
1. Klean Strip Stipper - poor choice, the raw urethane material absorbed this and became bubbly. Luckily I only sprayed a little to test it and was able to scuff it out. DO NOT USE.
2. Isopropyl Alcohol - I used this after I washed, scrubbed with Scotch Brite green pads. No issues here, good clean.
3. Bulldog Adhesion Promoter - Expensive and not for the novice. It came out splotchy and did not spray evenly. I finessed spraying this the best I could and I dont like it. So I bought the Dupli Color ad pro.
4. Duplicolor Adhesion Promoter - A third of the price and sprays and works fantastic.
5. SEM Primer Flexible Primer Surfacer - Havent used yet but it'll go over the AD PRO.
6. Rust Oleum High Performance Enamel Gloss Black - Sprays very fast and looks pretty good so far.
7. Rust Oleum Crystal Clear Enamel - I made the mistake and bought this...its NOT a clear coat. Ill have to buy the correct stuff.
Attached Thumbnails Urethane Replica Wald Trunk Spoiler Paint not sticking-0416161151.jpg
Old 04-16-16, 08:13 PM
drwafk
drwafk's Avatar
Default Update
Heres an 'in progress' update while I wait for the paint to dry. Adhesion Promoter and Flexible Primer went on just fine. If anyone is watching, think its ok to wetsand the black gloss to remove the imperfections prior to clear coating without respraying another coat of black? I have sand paper all the way up to 3000grit. For some reason the paint came out ... bumpy. Its adhearing just fine to the primer...I think its the type of paint. Rust Oleum Black Gloss.
Edit: I just read that using anything greater than 600 grit is bad because its harder for paint to stick. Also wet sanding the base paint without repainting is a NO GO. I'll sand to clear up imperfections, paint using a different black, then clear coat.
Attached Thumbnails Urethane Replica Wald Trunk Spoiler Paint not sticking-0416162106a.jpg   Urethane Replica Wald Trunk Spoiler Paint not sticking-0416162106.jpg
Old 04-17-16, 07:50 AM
Icy350
Icy350's Avatar
You should only Wet sand the Clear coat. going from 1000 grit, to 1500 grit, ending in 2000 grit. Then you would want to use a cutting crème of some kind to even it out, and then you want to finish with a mirror like glaze polish on top. Both cutter and polish should be applied using a buffer with the proper buff pads for each respective application. How did you spray it on? It looks like it was sprayed on really heavily. As in you held the spray and moved slow.
If you want, you can look up proper paint spray techniques. You are supposed to go back and forth using light sprays to give it an even flat finish. It takes more effort and time but the end result is night and day.
Old 04-17-16, 07:56 AM
drwafk
drwafk's Avatar
Thats what is puzzling, I spent all day yesterday patiently spraying and waiting. Each coat was basically 'misted' on. I did not spray heavy at all. I sprayed evenly and lightly with even sweeps back and forth about 6-12 inches away. Project is over for now anyways, I wanted to start over so I stripped the paint with some harsh chemicals (that I said I wouldnt use) and now its warped to crap. Back to square one.
Old 04-17-16, 08:29 AM
Icy350
Icy350's Avatar
It could be the paint then. My base paint comes on more like a flat finish. Very even and smooth. Try giving duplicolor a try. It sprays pretty nicely. Or you can use my source Paintscratch.com. They color match wel for OEM colors of any make or model. It just costs a tad more.
I spent all day sanding off the paint LOL. Took like 2 hours to sand everything off to its black base. I will be painting it today so Ill post my progress to give you an idea on how its supposed to look like after each stage.
Quick Reply: Urethane Replica Wald Trunk Spoiler Paint not sticking
