How to turn off CHECK AWD message?
Old 02-27-16, 01:54 PM
JDUB509
JDUB509's Avatar
Default How to turn off CHECK AWD message?
The CHECK AWD message came on on my 09 IS250 AWD. How do i fix or just turn it off temporarily until i get around to fixing it permanently?
Old 02-27-16, 03:16 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Really the only way to turn off the message is to fix whatever is wrong with your AWD system so that the error is no longer present.
Jeff
Old 02-28-16, 08:26 AM
Awd250
Awd250's Avatar
Agree with Jeff..no way to turn it off till you fix the problem with car
Old 02-28-16, 02:00 PM
JDUB509
JDUB509's Avatar
Any idea what the problem may be without me having to take it to the shop
Old 02-28-16, 02:30 PM
Awd250
Awd250's Avatar
Try checking your speed sensors..I had the same issue when my rear speed sensor broke when I was changing out my wheel studs
Old 02-29-16, 06:50 PM
NYKnick101
NYKnick101's Avatar
usually there are 2 main symptoms for this speed sensors because its saying your one wheel is rolling at a different speed than the others. (as mentioned above)
OR
you actually have wheels rolling at different speeds like wheels with different tire sizes
Old 02-29-16, 06:55 PM
JDUB509
JDUB509's Avatar
Is there a DIY fix?
Old 03-01-16, 04:39 AM
Eduskator
Eduskator's Avatar
Unless you have some solid knowledge, I don't think so. You can still google it and try to diagnose it yourself with your findings.
Bring it to a garage for a diagnosis. He'll tell you what's wrong, then you can fix it yourself, depending on the job.
Old 03-01-16, 05:29 PM
NYKnick101
NYKnick101's Avatar
Some of the newer code readers have vehicle specific codes. I think the check AWD is one of them that will tell you if its a speed sensor or drive train issue.
jonathancl
02-25-18 12:59 PM
IdahoRC
RC - 1st Gen (2015-present)
11-05-15 07:41 PM
Yuri101
01-22-12 12:59 PM
greg0723
10-11-09 03:35 PM
Overclocker
06-30-08 11:48 AM
Quick Reply: How to turn off CHECK AWD message?
