2009-10 F-Sport Grille with RX Emblem (w/Pics)
Hi Everyone,
I recently got my hand on a 2010 PCS F Sport Grille but realized the emblem is larger than our normal emblem size. After some research, the PCS version is bigger due to sensor behind it. I ran into another thread below, showing that the 2011 GX emblem was able to fit a 4 Gen GS PCS Grille. I was wondering if anyone knows the Emblem fitment for 4th Gen GS and 2nd gne IS PCS Grille are the same so I can use purchase the same ones?
https://www.clublexus.com/forums/gs-...-fsport-3.html
Couldn't get a response so I ended up trying using a 2010 RX emblem holder, part number below.
75312-0E011
BASE, RADIATOR GRILL
75311-0E020
EMBLEM
Sand down the selected area to make space for the emblem holder
emblem holder can now fit on the grille but not perfertly
test fit, the finish result is more flush since i ended up sanding the emblem holder on the bottom corner
front view
superglued washer to the grille to mimick where the emblem should clip into place for other Lexus grilles
inserted the nuts after the washers are secure and dry
finish result
75312-0E011
75311-0E020
EMBLEM
front view
finish result
black gs30
10-16-08 02:20 AM
