Check Engine light came on & (check vsc /traction off ) please help :(
Old 01-26-16, 07:14 PM
mishal88
mishal88's Avatar
Exclamation Check Engine light came on & (check vsc /traction off ) please help :(
error codes
Few more
Which parts do I have to replace? Any suggestions? Please help me out guyz
2008 Lexus is350 rwd
Old 01-26-16, 09:55 PM
MWIS350
MWIS350's Avatar
Maybe you need two new O2 seners for the front. They're same part number.
Old 01-26-16, 10:03 PM
mishal88
mishal88's Avatar
Do you know the part # and which brand is better ngk or borsch
Also I'm worried about the error code *P0606 pcm/ecm processor fault
Any idea what it means?
THANKS
Old 01-27-16, 12:30 AM
isfdude
isfdude's Avatar
THANKS
No.... The front 02 sensors are different!!! The rear sensors have a crown to protect the wiring from road debris. They are side specific as well and different from the is250 and is350. The best company to go with is Denso, that's what the dealer used on our cars from the showroom use nothing else or you will be doing it twice.
Old 01-27-16, 12:32 AM
isfdude
isfdude's Avatar
And another thing, the computer processor code will also go away along with the 02 sensor codes when you change it. It's cause by the wiring being ripped out from hitting something in the road and shorting out the computer that reads the level of the 02 sensors.
Old 01-27-16, 12:46 AM
mishal88
mishal88's Avatar
Alright I will go with denso, and do I have to get the upstream or the down stream sensors?
Old 01-28-16, 12:58 AM
isfdude
isfdude's Avatar
Your codes are for both downstream. The p0138 and p0137 are the downstream passenger side AKA bank 1 and the p0430 is the driver side downstream AKA bank 2 downstream sensor. These sensors are a pain to get too. You need a mild deep socket 02 sensor wrench to take it off because of the crown and they plug in under the driver and passenger seats of the car. Be carful not to twist the new wires when installing the new sensors.
Old 01-28-16, 03:15 AM
mishal88
mishal88's Avatar
Alriggg thanx
Jbakyy
12-13-22 10:35 PM
GenoG
12-01-21 01:57 PM
edgeucated
11-24-19 01:26 AM
07is350co
01-01-16 03:09 AM
Icy350
05-21-11 04:32 AM
Quick Reply: Check Engine light came on & (check vsc /traction off ) please help :(
