eBay VIPMotoz LED Headlights
Old 11-24-16, 11:41 PM
  #106
5nX37
5nX37's Avatar
Originally Posted by Joelseff
you will need to do both.
Excuse the delayed response, but isn't there only one fuse to tap into? If both headlights are needed to be tapped, where would the other headlight tap into?
Old 11-28-16, 08:45 AM
  #107
kwanye
kwanye's Avatar
Correct. You cut the led wire on both headlights, connect those 2 wires into one, and run that wire with an add a circuit to the driver side fuse box
Old 11-28-16, 11:18 AM
  #108
whitebeast
whitebeast's Avatar
In my case, I have to run 2 replays (one for each headlight ) to eliminate the flash on DRL LED. Some other people was success without needing of the replay. Make sure run the wire and turn on your headlight to check for flashing (engine must be on as well).
Old 12-16-16, 09:40 AM
  #109
Joelseff
Joelseff's Avatar
Soooo, we got a major downpour here in the bay last night. When I got home i checked my lights and the driver side was perfect...the passenger side however had condensation I contacted VIPMOTOZ and they were quick to respond even at 9pm PST. I mentioned I am a member here. They said it might be the grommet as they come loose or crack over time. They are sending me 2 new ones free of charge and they said that if that doesnt work, I can send it back to them and the y will test it for leaks and re-seal it free of charge. Even will cover shipping! Now that is cust service. So hopefully I can fix this because I have been loving these lights since installing them and Sewell stopped selling their upgrade kit. If these tank I'm gonna retro my original lights.
Old 12-16-16, 03:23 PM
  #110
whitebeast
whitebeast's Avatar
Yes, their customer services is top notch with worry free. I have very first set of them and so far so good. No leak or so whatover
Old 12-16-16, 03:51 PM
  #111
MikeyK02
MikeyK02's Avatar
It was a major reason it made sense to buy from them. Lexus would've told you to pound sand
Old 12-16-16, 05:36 PM
  #112
liqB
liqB's Avatar
Is there a way to make the LEDs brighter. I already tapped the green wire to my fusebox.
6speedLex (06-18-17)
Old 12-16-16, 07:06 PM
  #113
whitebeast
whitebeast's Avatar
Sorry to say NO. Did you have flashing problem when engine is on?
Old 12-17-16, 08:06 AM
  #114
top5
top5's Avatar
You're lucky. I emailed Louis about my turn signals not functioning and no one replied. I guess it's hit and miss with VIPMotoz.
I've had previous correspondence with Louis and he was great when it came to ordering questions.
Old 12-17-16, 11:25 AM
  #115
Joelseff
Joelseff's Avatar
I just went on ebay and messaged them. A guy named Chris responded in like 5 minutes. It was 9pm my time and was surprised to see them up. There's also a phone number you can call and their tech support is after hours too I think. I say keep trying.
Old 12-17-16, 05:59 PM
  #116
whitebeast
whitebeast's Avatar
You, Chris is very good at customer service. Anyway, good luck guy
Old 12-17-16, 11:12 PM
  #117
IamLexus
IamLexus's Avatar
Here's mine with HID Kit! (:
Old 01-08-17, 12:52 PM
  #118
crazy8ship
crazy8ship's Avatar
I just ordered these. Has anyone tried using a LED low beam bulb instead of buying a HID kit? I see they are aren't much of a price difference but I know HIDs tend to have issues.
Old 01-15-17, 04:22 PM
  #119
Joelseff
Joelseff's Avatar
Default Update
Ok... So i have been going back and forth with vipmotoz. They have sent me grommets which I think will seal the back of the light better. I was going to send back my light to them to check it and reseal it but I think it would be easier (less hassle) to just reseal the lights with another bead of silicone.
Now... Since my car has been out of commission since the fogging a few weeks ago and to be honest I am about sick of this whole thing. Not blaming Vipmotoz, they have been helpful and sent me the grommets free and offered free return shipping (though I had to pay for shipping to them)
​​​​so don't get me wrong its just i don't have the time to do all this and I need my car back (right now the bumper is off as i don't want to keep doing this my back can't take it). Plus I don't know how to seal a light lol.
I decided to just Polish my old lights, seal them with opti lens and put them back on. Headlight restorer came out this afternoon and the stock lights look great! They may not have the new swoosh Led look but no compromises either. I get AFS and auto leveling back and since my car is still under CPO warranty no hassles for repairs on them if needed. And the big one.... MY STOCK LIGHTS DON'T LEAK!
Soooo now I have an extra set of vipmotoz lights with morimoto xb35 HID. They also have 3 coats of Optimum Optilens which are supposed to protect from UV for the life of the car and must be sanded off to remove.
I don't mind eating the 600 bucks I spent on them (lights plus morimoto plus opti lens) but if anyone wants the set here I will let it go for cheap. I'd rather get it to someone who will use them who doesn't mind a little project and maybe recoup some of my money. Disclaimer: the passenger side has condensation/leak issue 😊. PM me if interested.
Old 07-04-17, 07:52 AM
  #120
See5
See5's Avatar
Installed my set, they are aiming toooo low need to remove bumper to adjust. I will be waiting for my HID but am planning to put LED on high beams as well.
Did anyone succeed installing LED H1 High beams? if yes please share product link as I need to see how much room is there to fit an LED with the dust cover on.
Also how does the LED compare to the stock H1 halogens ?
Lm?
Wattage?
Thank you
Quick Reply: eBay VIPMotoz LED Headlights
