Toyota Conventional Oil to Synthetic Oil?
Old 12-04-15, 02:04 PM
IamLexus
IamLexus's Avatar
Default Toyota Conventional Oil to Synthetic Oil?
I been going to the Dealership to get my oil change, and by the look on the receipt it shows that they had use Toyota conventional oil. Their is a deal going on with Advance Auto Stores 5-Qt Quaker State Full Synthetic Motor Oil + Purolator Classic Oil Filter for $9.99 .
Is this a high quality brand (the oil filter as well) and will switching conventional oil to full Synthetic be a problem? My IS is a 07 with about 124,xxx miles on it.
Old 12-04-15, 03:31 PM
toyoman29
toyoman29's Avatar
I would stick with the OEM filter, switching to full synthetic should be fine, I like Mobil 1 and have been using it for many years with no problems.
Old 12-04-15, 03:50 PM
20LS01
20LS01's Avatar
Quakerstate is a high quality synthetic. It is made by Shell which also makes Pennzoil. Honestly, any oil in the right grade will perform very well. Synthetic will just let you run the oil a little bit longer and have better startup flow in frigid locations. You can run synthetic at your mileage.
akcao
02-09-22 03:46 AM
05RX330AWD
06-19-17 05:10 PM
Mike
RX - 1st Gen (1999-2003)
12-16-07 10:50 AM
asianrage
10-04-07 06:15 AM
clubaddict
Maintenance
06-05-06 05:30 PM
Quick Reply: Toyota Conventional Oil to Synthetic Oil?
