Shifting kills engine
Old 11-09-15, 05:13 PM
jhuey
jhuey's Avatar
Default Shifting kills engine
When I put the car into reverse and then back to drive the engine shuts off. The shop is saying I need a new transmission and wants 5K. Can any of you guys help with why this is happening. It drives fine besides that.
Old 11-09-15, 10:34 PM
DryEye
DryEye's Avatar
Are there other symptoms such as rough idle, low idling? Might want to check hoses for cracks/splits, air leaks on intake, etc. There are many reason why this is happening. Even a dirty throttle body could cause this to happen.
Old 11-10-15, 08:57 AM
getafewliv
getafewliv's Avatar
Are you fully stopped before you put it back in drive?
Old 11-10-15, 09:35 AM
jhuey
jhuey's Avatar
There are no other symptoms I can tell for the reasoning. It drove fine, went into reverse fine but after backing up when I engage back to drive it just shuts off. Doesnt even shake or anything like that.
Yeah car was stopped before shifting. its weird it just shuts off. But it doesnt seem to happen when it goes from park to reversing to driving.
Old 11-10-15, 09:50 AM
Zynthe
Zynthe's Avatar
Can you try shifting to Neutral first then to drive? Does the same happen?
Old 11-10-15, 10:02 AM
jhuey
jhuey's Avatar
Do you mean stay in neutral for a a little? Technically I go through neutral from reverse to drive right?
Old 11-10-15, 01:00 PM
jhuey
jhuey's Avatar
It doesnt happen all the time but currently there is check vsc light and check engine light on too.
Old 11-10-15, 01:57 PM
Bichon
Super Moderator
Bichon's Avatar
Check VSC comes on whenever the check engine light is on. Have you read the codes?
Old 11-10-15, 02:08 PM
Gville350
Gville350's Avatar
^Start there; pull the codes (can be done free at most auto part stores) and let us know what they are.
Do you have an IS250 or IS350?
Does this problem ONLY happen when cold or does it happen also when at operating temp?
hamzabajwa
LX - 3rd Gen (2008-2021)
05-09-19 01:05 PM
ChrisGS350
07-13-17 12:55 AM
STREETGS
10-04-16 03:30 PM
Andy2na
17
10-09-14 05:25 AM
rct20
Maintenance
11-11-04 01:29 PM
Quick Reply: Shifting kills engine
