Power surge?
Old 11-03-15, 01:47 PM
darylrsv4
darylrsv4's Avatar
Default Power surge?
Last night on the way home on the freeway, I started getting a power surge. Car is an 08' with 91k. Kind of coincidental that I got an oil change yesterday. Looked under the hood to see if anything was loose and see nothing. Car drops rpm's with no power for a few seconds and then normal. No CEL's.
Anyone have an idea? Any help is appreciated, thank you..
Old 11-04-15, 02:25 PM
Gville350
Gville350's Avatar
Sounds really random. Perhaps try resetting the entire vehicle by disconnecting the battery for at least 20 minutes. It'll be like rebooting a PC after weird stuff happens. It might help, or it might not.
Old 11-06-15, 12:17 PM
darylrsv4
darylrsv4's Avatar
Hasn't happened since, pretty odd. Thanks for the response though..
Old 11-18-15, 02:26 PM
darylrsv4
darylrsv4's Avatar
This is happening again but more frequently. Was just at the dealer for a recall and told them about it and they told me oil possibly got on an O2 sensor when I got the oil change. It is now happening more since I was at the dealer so that theory isn't possible. Still no CEL's.
Anyone else with ideas?
Old 11-19-15, 12:47 PM
Gville350
Gville350's Avatar
How would oil get on (either inside or outside the exhaust) the O2 sensor during an oil change? WTF?
Old 11-19-15, 12:55 PM
whitebeast
whitebeast's Avatar
i would check grounding wire first if i were you. IN some case, The loosing ground have same problem. Check it!
Old 11-19-15, 02:55 PM
Byprodrive
Byprodrive's Avatar
Fuel pump going bad? Do you often run your tank extra low on gas?
Old 11-23-15, 12:41 PM
darylrsv4
darylrsv4's Avatar
This still has me baffled. In the warm temps, 75-85 no issues. When the Temps at night drop into the 40 -50's is when it is happening.
calteg
IS F (2008-2014)
10-22-14 07:33 PM
milellie11
10-17-11 10:30 AM
xenonrider
01-01-10 03:29 PM
roy1928
Performance & Maintenance
07-21-08 04:48 PM
Quick Reply: Power surge?
