Car not starting after pumping
Hey guys im trying to find out wats wrong with my is250 every time i pump gas the car wont start till the 3rd try i have a check engine like for evaporated emission sistem but im not sure were is that located at.... Ill apreciate u guys help
Super Moderator
Why are you pumping the gas at all? Just put your foot on the brake and push the start button.
Evaporative emissions codes are frequently caused by a loose or bad gas cap. Could also be clogged charcoal canister, problem with purge control valve, etc.
I changed the cap already
it all started when they did the recall for the fuel leak its only when i pump gas any other occasion it starts up perfectly
well, if you have already changed the gas cap, why don't you just bring your car back to the dealer and tell them that you are experiencing problems after the fuel leak recall.
Super Moderator
Agreed!
(This question sounds familiar...)
^^ Agree with Mike.
Check that your EVAP purge solenoid is not stuck open. If it is stuck in the open position, it can flood your engine after you've filled gas. Pressing the gas pedal down and trying to start the car puts most fuel injected cars into a "clear flood" mode that limits fuel delivery until the car starts, which is why you can start it after pushing the gas pedal down.
Check it out, it's a cheap part that can be changed pretty easily if that's what it is.
Good luck!
^^ Agree with Mike.
Good luck!
