IS250 Camshaft position sensor Location??
have P0340 camshaft position sensor "A" circuit - bank 1
also have cam gear noise problem which is IS350 had recall.
anyone help me to find out where is the sensor is? please.
thanks
thanks
Since this the brother sensor in this thread, it'll be on the other side of the engine...but will be the exact same looking sensor :
https://www.clublexus.com/forums/is-...ft-sensor.html
sufiyan (08-20-23)
The intake cam sensor is mounted highest, the exhaust is lower and towards the rear middle. Inspect the plug connector and wires at the sensors which are a single 10mm bolt for each each all black sensor.
Do not confuse the silver metal solenoids with sensors.
cpa786 (12-08-21)
Thanks for the helpful info, battery died on me this AM (although 2 months old), jumpstarted and runs fine but threw a CEL after jumping - had my mechanic clear it said it was Camshaft Pos. Sensor running fine now but alternator may be on its way out (reading around 13-13.3).
Batt is under warranty and I found a cheap OEM alternator. so will replace that, but this code hasn't come on again but in case it does, how many CS Pos. sensors does this things have (2013 GS AWD)? Are they the same sensors part wise? Seems an easy fix, just not sure if this was the reason the batt died today or not.
Any other work done to it recently? Usually it's during a plug swap or other repairs that something gets messed with.
IDK about the part numbers. But a Where Used with a PN should give a count of how many. That said, the sensor is rarely the problem.
Get the charging system and battery fixed before chasing this as it could be related. They do strange things when batteries die.
