AD2P support in later Lexus HU's swap bluetooth unit.
Old 08-26-15, 06:39 PM
zazzn
zazzn's Avatar
Default AD2P support in later Lexus HU's swap bluetooth unit.
Hi All,
I was taking apart my radio unit to fix the non working screen on my IS-F, anyways, I came across the bluetooth unit from Denso, and started to wonder if it was really only the unit that needs to be updated to support AD2P?
Basically, would the bluetooth unit from a 2011+ give AD2P to a 2008 model? Thoughts?
Attached Thumbnails AD2P support in later Lexus HU's swap bluetooth unit.-image1.jpg
Old 08-26-15, 06:51 PM
zazzn
zazzn's Avatar
More digging on the FCC number I found a slew of parts for toyota specific items made by denso.
Intresting to see what they have and when they were submitted. There's a Canbus Bluetooth ECU there. When I google the number it shows a bunch of Formula E cars...
This item seems to be the old Toyo BT HU
https://fccid.io/HYQDNNS016
https://www.google.com/search?q=DNNS...IVx0uICh2ZjQxC
Also searching for BT AU01 instead of HYQBTAU01 shows up a **** load of BT receivers, which I guess is the same as what is used in the Cars.
Old 08-27-15, 08:19 AM
A1cntrler
A1cntrler's Avatar
Interesting. Replied to follow. 2006 350 owner here and would also like to see if swapping a unit would work for AD2P
Old 08-27-15, 03:14 PM
pavelekPL
pavelekPL's Avatar
Originally Posted by zazzn
Hi All,
I'm sure in 99.9% that replacing the Bluetooth unit would not give you ad2p support. How would the unit know you wanna stream the music via bluetooth? No extra menus would show up, that's for sure. If anything the unit itself would need to have the software flashed first.
Old 08-27-15, 06:03 PM
synrgy350
synrgy350's Avatar
Plus you could just get something like this and plug it into your aux jack:
Amazon.com: Etekcity NFC-Enabled Bluetooth 4.0 Audio Receiver / Music Streaming Adapter for Car & Home Stereo Sound System: Electronics Amazon.com: Etekcity NFC-Enabled Bluetooth 4.0 Audio Receiver / Music Streaming Adapter for Car & Home Stereo Sound System: Electronics
Most modern smart phones can do dual bluetooth streaming so it will be connected to the car and the receiver for music. It's what I use in my 350.
Old 08-27-15, 06:54 PM
smokyis350
smokyis350's Avatar
I have been using a AD2P for over a year now and it ahs been working flawlessly.
Old 08-27-15, 07:52 PM
zazzn
zazzn's Avatar
I realize there is something that can plug into AUX, but I'm sure they didn't redesign the whole HU just for AD2P in the case of the Denso BT antenna yet have a pioneer HU for the ML sound system.
I wish someone with a AD2p support HU would open up and check what unit they have in there.
Would make it easy to buy and then test that unit.
Alibaba has the unit i listed for like 20 bucks.
Old 08-27-15, 08:25 PM
A1cntrler
A1cntrler's Avatar
With this setup, while you'll still get the audio through, you lose the capability to control the phone from the steering wheel controls. You'll still need to advance to the next track by touching your phone.
Old 08-27-15, 09:43 PM
mier
mier's Avatar
subscribed.
Old 08-28-15, 03:06 PM
pavelekPL
pavelekPL's Avatar
I realize there is something that can plug in to AUX, but i'm sure they didn't redesign teh whole HU just for AD2P in the case of the denso BT antenna yet have a pioneer HU for the ML sound system.
Ok so i just realized i have a +2010 HDD nav sitting in my garage I'll open it up tomorrow (if i'll have time) and let you know what's what. Also +2010 navigation uses a separate 'multimedia' module that hooks up to the navigation unit.
Old 08-28-15, 04:24 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
I believe a lot of the added functionality is in the separate multimedia module added on the 2010+ models.
Haven't looked at it extensively though, since my car came with it, haha.
Jeff
Sadielou
11-03-18 07:22 AM
Caffeine27
LX - 3rd Gen (2008-2021)
03-22-18 02:10 PM
jbl-1985
06-19-15 08:47 AM
Jodwin
10-07-14 12:19 PM
Quick Reply: AD2P support in later Lexus HU's swap bluetooth unit.
