2007 IS350 Transmission Issue
Old 08-17-15, 09:11 PM
Kenny88880
Kenny88880's Avatar
Default 2007 IS350 Transmission Issue
This posting was removed.
Old 08-18-15, 09:02 AM
B16da9
B16da9's Avatar
Back when Sewell was selling parts online they offered a rebuilt transmission for around $2,500.00 with core. I would contact them and see how much it would be as it might be the best option to you especially if you can do the work youeself.
Old 08-18-15, 09:22 AM
getafewliv
getafewliv's Avatar
Pro tip for next time, if something as serious as the transmission starts acting up like that, continuing to drive greatly increases the chance of serious damage vs. just needing the seal replaced and fluid changed.
Hopefully it just lost enough fluid to operate properly and didn't cause any damage.
Old 08-18-15, 11:32 AM
Kenny88880
Kenny88880's Avatar
Old 08-18-15, 12:28 PM
Gville350
Gville350's Avatar
I hope for your sake that a new seal and fluid fixes it for you. Do take pics, as others like me like to continually learn about our cars inside and out.
Old 08-20-15, 10:26 AM
Kenny88880
Kenny88880's Avatar
Old 08-20-15, 02:25 PM
Gville350
Gville350's Avatar
Unfortunately without seeing the condition of the plates/gears/bearings/etc for excessive wear or heat due to running low on fluids, we cannot give you the best advise on your existing trans there. MY OPINION is to source a known, good working used trans...not a reman.
Good luck!
Old 08-21-15, 06:52 AM
Kenny88880
Kenny88880's Avatar
This posting has been removed.
Old 08-22-15, 08:43 PM
synrgy350
synrgy350's Avatar
Looks like your torque converter hub seal blew out. I've never seen this on a Lexus transmission before, do you drive this car really hard?
Old 08-24-15, 06:58 AM
Kenny88880
Kenny88880's Avatar
Old 08-24-15, 07:04 AM
Kenny88880
Kenny88880's Avatar
Old 08-24-15, 12:39 PM
Gville350
Gville350's Avatar
Could pick up a good, used trans for $1k in your area.
Any thoughts about upgrading to Megan engine/trans mounts while everything is under the knife?
http://www.meganracing.com/product.a...=1532&catid=91
and...
http://www.meganracing.com/product_d...=1785&catid=91
Old 08-24-15, 04:21 PM
SebaPR
SebaPR's Avatar
omg try to find a cheaper shop my auto is250 trans broke needed new torque converter and one new clutch arm and fixing the other for 1st gear the repair summed up $1.6k total...
running strong for 6th months i drive hard and it feels better than before maybe because of new fluid.
Old 08-24-15, 05:49 PM
smokyis350
smokyis350's Avatar
+1. $4500 for a rebuilt is pretty pricey. Why not get a used transmission with low mileage off eBay, craigslist, or junkyard?
Old 08-24-15, 09:17 PM
Kenny88880
Kenny88880's Avatar
Quick Reply: 2007 IS350 Transmission Issue
