Is it worth to spend $50?
Well if it's just the tube and not the box , I suppose it's worth it since normally it's about $140 I believe? But whether it's really worth it to you is purely your opinion. All the tube is really supposed to do is make the car breathe a tiny bit better and give a very small increase in power of about 3-4 hp at best.
As far as sound , I'm not sure if it does much for the car if you don't have the F sport air box. In my case, I already have the F sport box but not the tube and that made my car have a meaner deeper growl above 3k rpm.
But whether you want it or not is up to you , and what's important to you . Essentually, you get a small increase in power (maybe) and better asthetics (opinion) for your engine bay.
Hope this helps.
Hope this helps.
Thanks guys for the great info, yeah the tube come with hose couplers and clamps, and now i have K&N air filter, it just look like the F-sport elements air filter, all i have to sand down the bottom fins inside the box to make it like the F-sport complete intake set up, yeah $50 why not right?
The big diff between fsport box and stock is the extra hole on the side. You should cut a hole in your stock one if u want sound, because that's where the sound comes from. I don't think the fins do much.
patrick323
02-11-09 02:00 PM
