Lowered with Staggered Wheels and tires.
Old 07-27-15, 12:54 PM
is250fsprt
is250fsprt's Avatar
Default Lowered with Staggered Wheels and tires.
Is it normal for the the tires to wear prematurely? I'm getting camber wear like crazy and that's with an alignment job already done. I have the F sport lowering springs on which is not to crazy of a drop probably an inch or so. Do I have a bigger problem? Had to replace the tires today because of the bad camber wear.
Old 07-27-15, 01:13 PM
metaleckz
metaleckz's Avatar
Front ? Back ? Or both ?
There is a solution for the front. The bushing from this one company. Too lazy to search lol
Old 07-27-15, 01:21 PM
nfordhk
nfordhk's Avatar
Well give us your wheel specs. Size, offset?
Did they set the camber and toe? Toe is much more important than camber.
It is normal to have above average tire wear with anything other than oem. It all depends on how dramatic that wear will be on multiple factors.
Old 07-27-15, 02:01 PM
Gville350
Gville350's Avatar
What was your alignment specs afterward...especially the toe? Look into new front LCA bushings from FIGs.
Old 07-27-15, 02:37 PM
is250fsprt
is250fsprt's Avatar
I have the 19" F Sport accessory wheels. They are 19x8 +40 in the front and 19x9 +40 in the rear. I have the alignment sheet somewhere in my glove box somewhere. I will take a look at it.
Old 07-27-15, 03:18 PM
jennie
jennie's Avatar
Pics? A lot of people mistake camber wear for toe wear. If you have crazy camber wear it might actually be your toe.
Old 07-28-15, 07:23 AM
Eldr1dgE
Eldr1dgE's Avatar
Camber is not your problem, its your toe. Like what Gville350 said, there are solutions for this.
Old 07-29-15, 04:24 AM
srt1
srt1's Avatar
Lol, you crazy bro.
Old 07-29-15, 07:28 PM
smokyis350
smokyis350's Avatar
Before you buy new bushing/camber kit. I would bring it to a more reputable shop for alignment. F-sport springs drop is very subtle. It shouldn't causing severe camber wear.
Old 07-31-15, 07:22 AM
is250fsprt
is250fsprt's Avatar
Took it to the Stealer and got new Michelin Pilot sport AS3 along with an alignment. I for got to the pictures of the wear on the Continental extreme DWS. I hope everying is all good now because I can't afford to blow $1200 on new tires that quickly. On a side note I really love these tires. They are quite and smooth. It even have curb guard.
Old 07-31-15, 11:05 AM
deestyle28
deestyle28's Avatar
I have the same setup. F sport springs, shocks, and sways. Alignment shop did the best they could because camber can't be adjusted on our cars unless you have after market camber kits. Everything on my car was within spec except for front driver side. Specified range is -1.1 to 0.4 to be in spec but mine was -1.4 for camber. Toe is all in spec. Like the others have said Toe is probably the most important especially if you have a mild drop.
Old 07-31-15, 12:13 PM
is250fsprt
is250fsprt's Avatar
So how to I get the Toe adjusted? Is it different from an alignment?
Old 07-31-15, 07:58 PM
VTsuckah
VTsuckah's Avatar
They will adjust toe during an alignment.
Old 07-31-15, 08:43 PM
smokyis350
smokyis350's Avatar
Don't bring to the dealer. They aren't experienced with dealing with lowered cars. I would recommend finding a local shop that specializes in alignment for track setups. They would know how to adjust the toe.
Old 08-03-15, 12:02 PM
Gville350
Gville350's Avatar
^Not a good blanket statement. I love my alignment techs at my Lexus dealership. They share their in-ground rack with the Porsche dealership next door. They've always done me well, plus I never have to worry about my lowered 2IS being ramped up onto a rack.
Quick Reply: Lowered with Staggered Wheels and tires.
