How much oil do you Add?
Old 07-24-15, 04:51 AM
gebo
gebo's Avatar
Default How much oil do you Add?
The Owner's Manual says to add 6.7 Qts with filter change in my '09 350. I did my first oil change last night and added 6.5 qts. Checked it this morning and it is in the "safe range", duh...
My question is:
For all of you DIY, do you add 6, 6.5, 6.7 or 7 qts. Obviously from looking at my stick this morning, 6.7 would seem to be perfect and put the oil level at the top button on the stick. I guess I'm toying with either 6.5 so i can save the other half for the next oil change or going with 7 which I don't think would hurt anything.
Old 07-24-15, 06:41 AM
liqB
liqB's Avatar
I personally add 7qt every oil change
Old 07-24-15, 07:03 AM
VTsuckah
VTsuckah's Avatar
6.7 here. I put in 6.5 qts, then keep checking the dip stick until I'm at the right level.
Old 07-24-15, 07:06 AM
Bichon
Super Moderator
Bichon's Avatar
Agree with VTsuckah; that's exactly what I do.
Old 07-24-15, 07:47 AM
Sffd103
Fire Slayer
Sffd103's Avatar
Put in what the manual says to put in. 6.7 quarts.
Old 07-24-15, 10:16 AM
jennie
jennie's Avatar
6.7 qts. I even bought one of those funnels that could measure .7 qts because I'm OCD like that.
I think it's better to underfill than to overfill your oil.
Old 07-24-15, 12:15 PM
darkdream
darkdream's Avatar
IF you are DYI, the amount of oil might vary depending on the angle the car is tilted unless you are jacking up the car on stands for an oil change. Just keep checking the oil with the dip stick. Too much oil will cause problems just as too little will.
Old 07-24-15, 05:27 PM
20LS01
20LS01's Avatar
Put in a cool 6 quarts. Drive the car, shut it off and wait a few minutes and add if necessary.
Old 07-24-15, 05:58 PM
Slammer1
Slammer1's Avatar
I've been adding 6.6 quarts every time for the last 5 years.
Old 07-27-15, 06:09 AM
firelikeiy
firelikeiy's Avatar
6.5 quarts just because it is easier. I check the level occasionally and it never goes below the halfway mark during the 5K mile interval.
Old 07-27-15, 01:00 PM
is250fsprt
is250fsprt's Avatar
I will always buy the 5qt Mobil 1 Jug and will always have single qt on hand. Every oil changes I just pour the 5 qts jug in and the 1 qt bottle then top off with another bottle pouring in a little more than half.
Old 07-27-15, 05:00 PM
MWIS350
MWIS350's Avatar
6.5 should be good. The. Check level next day.
block232
NX - 1st Gen (2015-2021)
23
02-18-20 07:57 AM
isosunrise
07-24-17 06:08 PM
lexus-is2
10-25-13 01:57 PM
SClean4
Performance & Maintenance
05-28-09 03:01 PM
schtebie
Maintenance
14
02-26-03 11:40 AM
Quick Reply: How much oil do you Add?
