What Oil Filter Are You Using?
Old 07-20-15, 02:23 PM
gebo
gebo's Avatar
Default What Oil Filter Are You Using?
First car I've ever taken care of with a cartridge filter. Are you using Toyota or some other brand?What filter are you using?
Old 07-20-15, 02:39 PM
metaleckz
metaleckz's Avatar
I heard wix is a good brand
Old 07-20-15, 03:10 PM
Bichon
Super Moderator
Bichon's Avatar
OEM filter is great quality and very reasonably priced; it's the only one I've used on this car.
Old 07-20-15, 03:18 PM
gebo
gebo's Avatar
If it matters, I'm gonna be using a synthetic at 10K OCI's. I'm wondering if the Toyota will be good for that long or if I should change it out at 5K?
Old 07-20-15, 04:29 PM
jennie
jennie's Avatar
I bought an entire box of the OEM filters and have never had a problem. I know Lexus recommends 10k intervals so it's only logical the filter will last that long.
Old 07-20-15, 04:37 PM
gebo
gebo's Avatar
Thanks for info! I did not know that.
Old 07-20-15, 04:44 PM
VTsuckah
VTsuckah's Avatar
I use only oem.
Old 07-20-15, 05:02 PM
toyoman29
toyoman29's Avatar
Toyota OEM, also replace the drain plug gasket each time.
Old 07-20-15, 05:08 PM
Sffd103
Fire Slayer
Sffd103's Avatar
only ever used OEM
Old 07-21-15, 12:53 PM
Gville350
Gville350's Avatar
OEM only here too.
Old 07-21-15, 03:12 PM
kickin8
2IS/2RX/4RX
kickin8's Avatar
Oem.......
Old 07-21-15, 05:06 PM
Basselc
Basselc's Avatar
What do you guys think of the Mobil 1 filters? That's what I normally use with Mobil 1 fully synthetic oil as well
Old 07-21-15, 07:03 PM
firelikeiy
firelikeiy's Avatar
I've been using wix but plan on going back to OEM when I run out. I bought 120K miles worth of filters when I bought the car...
Old 07-21-15, 07:56 PM
gebo
gebo's Avatar
Well.....I guess I got my answer
Just got 3 for $11.00
Old 07-21-15, 08:02 PM
Slammer1
Slammer1's Avatar
I've always been a Purolator filter fan, but have been considering Toyota filters lately. When looking the Purolator filters over, I've noticed inconsistencies in how the layers are grouped as well as "debris" (loose pieces of filter material stuck between the folds of their filters. I'm mental about most things but more so when it comes to oil filtration. Some of the filters I've looked at have folds that are really, really close together and others that are spread way apart. I will make a note to take some example pics in the future.
Quick Reply: What Oil Filter Are You Using?
