Likes/Dislikes for those that have owned for 3+ years
Old 07-18-15, 12:38 PM
jennie
jennie's Avatar
Originally Posted by 02SDGS
Based off threads like these, I'm starting to think Lexus quality isn't where it used to be
I think the quality is still there. All cars have their quirks, like the GS with the ball joints, climate servos, and door lock actuators.
Old 07-18-15, 06:10 PM
darkdream
darkdream's Avatar
I have never had any problems with the quality. My only complaint is I wish the car had a sportier feel to it.
Old 07-18-15, 10:19 PM
MWIS350
MWIS350's Avatar
That's when IS350 with 306 HP come in handy.
Old 07-18-15, 10:21 PM
MWIS350
MWIS350's Avatar
Originally Posted by srt1
Gotta say my 350 has given me ZERO problems, if it did I fixed it myself. Glad I didnt go with the 250awd
Wife just trade in her 2007 IS250 for ES350.
Old 07-19-15, 12:09 AM
BrownPride
BrownPride's Avatar
I know I shouldn't be chiming in b/c I've only had my '12 IS250 for a couple months now, but there are a few things I'm not a fan of:
1) Nav System is a bit confusing. My other cars had arrow display which made it clear where to go.
2) When I switch from Bluetooth --> FM --> Bluetooth (and vice-versa) it'll sometimes take a few seconds to start again, but most of the time I have to disconnect then reconnect Bluetooth. It's a pain.
3) Seating position is absurdly high. I'm just a hair under 5'10" and I sit very high even with the seat at the lowest position and reclined a bit. I had an E90 BMW which was also a "small" sedan but was much better in this regard.
4) Overall feeling of compactness in the cabin
5) Not much power and it guzzles Premium fuel
It sounds like I'm complaining a lot but I like the car a lot. It's just that I'm coming from an E90 BMW which was by far the best car in its class at the time. Heck I think it's better than the current 3-series. This Lexus is no BMW (which is my favorite brand) but I got it in order to have something more reliable and cheaper to maintain for the next few years. If I were to write up a list of things I like about the IS it would be 2-3 times the length of this cons list. Great overall car.
Old 07-19-15, 08:34 AM
darkdream
darkdream's Avatar
I have the IS350. Adding more power will not make a car sportier. It needs a suspension overhaul.
Old 07-19-15, 09:47 AM
Hoovey689
Hoovey689's Avatar
Nothing some F-Sport sway bars, F-Sport chassis brace, IS F steering wheel damper and stickier tires can't fix, maybe even coilovers if you're feeling frisky
Old 07-19-15, 12:00 PM
MWIS350
MWIS350's Avatar
Drop low, bigger rims, intake, header, midepipe, exhaust and rear sway bar will help.
Old 07-19-15, 03:16 PM
cc2001
cc2001's Avatar
Only issue I've had over the 5 years of ownership is that the cup holder position isn't great.
I've noticed my older 250 seats sits alot lower than the newer f sport 350 seats too.
Old 07-19-15, 04:48 PM
Wunko
Wunko's Avatar
I got my 2011 IS brand new.
My stock tires have inner tire wear already and I don't even have 15000 miles on the odometer. I was hoping they would last longer. I will probably need new tires soon.
Navigation system is sluggish when it comes to moving through the menus like switching folders on the USB music screen.
No heat issues but the AC does have the stink smell now.
Seat stitching on the driver's seat is also coming apart.
I could probably nitpick on other things but these are the main things I've noticed.
Old 07-19-15, 08:00 PM
MWIS350
MWIS350's Avatar
Inner tire wear you might need new ball joint and alignment.
Old 07-20-15, 10:50 PM
Wunko
Wunko's Avatar
I had an alignment done but never looked all the ball joint. I'll keep that in mind. Thanks for the info.
Old 07-21-15, 08:08 AM
hung8852
hung8852's Avatar
own the 2006 is350.. no real complaints except the tabs that holds the headlights up. both of them broke off. horrible design flaw. I bought new tabs which cost about 60bucks for two pieces of plastic. I have yet to install it. Cant think of anything else besides that.
Old 07-21-15, 05:04 PM
MWIS350
MWIS350's Avatar
When I got my alignment done machanic recommend new ball joint. It will fixed inner tire wear.
Old 07-21-15, 07:34 PM
firelikeiy
firelikeiy's Avatar
Inner tire wear is a known issue with these cars. It has to do with the steering rack placement and the soft compression bushings. When you brake the control arms arch back causing the tires to toe out. Some people have attempted to correct this by using FIGs racing bushings but that changes the cars handling characteristics from understeer to oversteer.
I have an '08 IS250 with 95K miles. Original owner.
Negatives:
1. Underpowered
2. Gas mileage is less than what the readout shows. My car shows around 30mpg but I really get around 26-27mpg and I drive 80% highway.
3. Lack of storage.
4. Car is cramped for its size.
5. Back seat doesn't fold down.
6. Engine is prone to carbon buildup. I use a 3m fuel system tune up kit every 15K miles and have an oil catch can.
Positives:
1. Interior quality is top notch (although people are having issues with the dash melting)
2. Exterior quality is top notch. Car is 7 years old and not a single door ding! (although I always park in the back of parking lots)
I've had the following issues while the car was under warranty:
1. Timing cover leak.
2. Failed water pump.
3. Driver side rear shock developed a leak.
Issues after warranty:
1. Cam gears are making noise on warm startups. Dealer quoted $2200 to replace. Cheapest I have found parts is just under $700 to do it myself. I will probably do it myself and replace the valve stem seals while I am at it.
Quick Reply: Likes/Dislikes for those that have owned for 3+ years
