2008 IS250 Shift Shaft Seal! Can't get out! HELP! Leaking! Mechanics PLEASE
Hello. I have a 2008 IS250. I noticed leaking near rear main seal but then realized the actual "Shift Shaft Seal" above the rear main seal is completely out so I'm losing fluid quick! I already replaced rear main seal to be on the safe side, but I need to replace the shift shaft seal as well, however I can't seem to figure out how to get the swivel piece off, I got the linkage piece off from it but I can't get the actual swivel out of my way so I can completely remove the seal and replace it! I am providing a photo of what I'm talking about, if anyone knows how to get this off please tell me... I'm up a creek right now! Can't put it all back together until I figure this out and I would hate to have to tow to mechanic just for this failure on my part... Well I could reassemble and then take to a mechanic to do that seal, but they would charge hundreds for something I know I should be able to do!
This is similar to my transmission on the left... but both have a similar swivel thing... I have looked all over the net and everything says or points to a pin that goes all the way through and must be removed before you can move this part... But mine doesn't have such a pin at all! Please help : (
This is an example of one with the pin I have sought out and been told I have to remove.... But mine doesn't have the pin like everything says and points to!
Shift shaft seal
Need to slide the metal sleeve down. Then you'll see the pin
timmy0tool (11-30-22)
Jrgomez72
12-27-17 10:10 PM
