Help Installing Subwoofer and Amp
I was wondering is there a way i can install my system without getting into my factory radio? Maybe use the remote wire and connect it to a fuse that has power? IF anyone can help me on this topic, that'll be great..
Yea like Nguyen said, I would tap the remote into the cigarette lighter in your armrest center console. I'm sure it wouldn't take much to get to and run it from there.
Do you already have a amplifier? if not then buy the one without a remote wire requirement. mine turns on with RCA cables. its all connected to oem amplifier in the trunk. did not have to touch the radio at all
Ok thanks! Yeah i already have an amp. So is it hard plugin the rca cables from the factory radio without taking it apart? Or should i just use a converter?
Gotcha. One more thing, i wanted to install a two pin kill switch and was wondering if i can install one wire which is the remote to one pin connected to a fuse that has power and then wire the other pin and connect it to the remote to my amp? So i can use the switch to turn it on and off. Thanks!
Sheehan1p
01-15-10 03:42 PM
