IS-350 Check Engine, VSC light, traction, Engine shake at stop light.
Have anybody experience this issue? Idle also go up and down. I will take it to Orielly Auto Parts tomorrow to scan for code. Thank you.
Super Moderator
My local mechanic and separately my Lexus service advisor said there were IS350s with the same issues. Just from the symptoms it sounds like carbon build up. I had the same issue. Cold start in driveway, fluctuating idle, then the car died, CEL, VTC, tractions light all came on. Took to Lexus and they diagnosed the misfire and carbon build up. Scoring on the cylinder walls 5/6 cylinders, got a new short block with rebuilt heads.
Won't really know unless you pull the codes. I hope for you that it's not carbon build up. Just sounds like it from what I've experienced.
Sorry. I have a 250. They did cover the entire short block and head rebuild along spark plugs and all the fluids. My service advisor is pretty good about doing things/getting things done for me w/o cost. Your milage my vary.
Got three code Bank 1, Bank 2 system too rich and bad MAF Sensor.
Maybe that's why my car feel lack of performance. Spark plug was black, Exhaust smell bad.
