LED Headlight Bulbs
Old 06-19-15, 08:32 PM
cruzck
cruzck's Avatar
Default LED Headlight Bulbs
I've been trying to find the perfect white bulbs for my headlights. I keep seeing Audis and BMWs with crystal white lights. Googled them and seen that they used LED bulbs and that Audis especially have some special LED headlights.
My question is, is there a bulb out there similar to its pure white and bright LED bulbs I can buy? I have an 2009 Lexus IS250.
Thanks guys.
Old 06-19-15, 10:12 PM
whitebeast
whitebeast's Avatar
You want LED for your low bean? 6000K -6500K is what you're looking for if you want for your lowbean.
Old 06-19-15, 10:14 PM
MWIS350
MWIS350's Avatar
Check out Amazon.com they got good price. Just bought pack of 2 for my IS350 HID low beam $56.
Old 06-19-15, 11:00 PM
cruzck
cruzck's Avatar
Do you guys know the fittings for the low, high/drl, and fog bulbs?
I'm pretty sure I read somewhere that the low beams are the H11?
Old 06-19-15, 11:44 PM
cruzck
cruzck's Avatar
Amazon shows me a lot of results and I'm not too sure about what I'm looking for still. I see some that looks like it comes with a ballast and some just as bulbs. I was sort of hoping it would be a literal bulb switch and not have to drill holes or anything like that.
Old 06-20-15, 10:20 AM
MWIS350
MWIS350's Avatar
when you type in year and model of your car. It will show if it the right one for your car or not. When you click on the product.
Old 06-20-15, 10:00 PM
Kvs_350
Kvs_350's Avatar
Is ur car oem hid equipped? For oem hid equipped low beam d4s high beam/DRL 9005 fog light 9006 parking light 194 168 and if u have halogen low beam is h11 all other bulb are the same. U could use led kit but u need to becareful of buying led kit that the bulb will be able to fit inside the dust cover.. some led bulb are freaking huge and ofcourse u have drill through ur dust cover to wire the ballast. Led kit r not as bright as hid kit so take ur pick
Old 06-21-15, 01:15 AM
QuocTran
QuocTran's Avatar
Don't LED bulbs run at lower lumens? I think they're at 2500 lumens vs 3000 on HIDs at 5000k. I could be wrong.
Old 06-21-15, 08:41 AM
nosurprise
nosurprise's Avatar
LEDs are not as bright as HID but might be brighter than halogen. I think the newer Lexus cars use LEDs as well. I do wonder how long they last as LEDs decrease in light output as they aged (instead of burning out, they just become less bright over time).
I have been looking a little bit for something that would just plug into the car to replace the halogens, but I don't think such bulbs exist currently. All of them seems to need some sort of heat sink to dissipate the heat and a driver (I think it's equivalent to a ballast to HIDs).
eternalkp
08-22-16 08:51 AM
430keeper
11-28-14 09:16 PM
charmz
General Classifieds
06-09-10 10:33 PM
Stealther
Lighting
04-08-03 12:15 PM
Quick Reply: LED Headlight Bulbs
