Very slow tire air leak
So I got a tire pressure warning about 2 weeks ago with the rear driver side tire showing 30PSI while all the other tires are fine. I filled it with air to about 38PSI, but now I have a low tire pressure warning again for the same tire at 30PSI.
What could cause this slow air leak? I'm planning to take it to Discount Tires or something. Is it generally an easy and inexpensive fix?
Check if your TPMS sensor is leaking, I had that issue before went to a tire shop multiple times they took the tire off inspected it and said everything was fine, after about the 3rd time they checked my sensor and that was the issue. Just spray some soapy water on it and if it bubbles thats the easiest way to check it at home.
Super Moderator
I had a slow leak right at the tire bead that was losing air at about the same speed as yours is. Tire shop dismounted tire, applied a thicker (black colored) bead sealer, and remounted. Been holding air great since.
Super Moderator
uae
03-10-08 09:16 AM
