Help! Car won't start... Any ideas why?
Old 06-01-15, 09:07 PM
Lexi20081
Lexi20081's Avatar
Default Help! Car won't start... Any ideas why?
Car wouldn't start today. Has crank and battery is good. Did some research and saw that it has a less likely chance of a broken timing chain. But the way it was sounding as it was trying to start sounded like something broke. Other research told me it could be a blown fuse or fuel pump. Will check all fuses tomorrow to start the process of elimination that but in the meantime I thought of ask if this has happened to anyone.
Any guidance you can give would be helpful. Thank you much!
Old 06-01-15, 10:46 PM
MWIS350
MWIS350's Avatar
Have issue with IS250 not starting before and turn out it is a battery.
Old 06-01-15, 11:01 PM
Lexi20081
Lexi20081's Avatar
Default Thanks!
Thank you, MSWIS350. I actually took the battery out and took it to the auto store I bought it at. They tested it and concluded that the battery is good... I've only had it for a little less than 2 years so should still be ok.
Old 06-01-15, 11:04 PM
nosurprise
nosurprise's Avatar
I have a couple of batteries failed in less than 2 years -- I'm not saying the battery is bad, but just saying battery can go bad randomly. Do you have a recording of the sound? I would actually try to jump start the car with another car if that's an option; to make sure it's not the battery.
Old 06-02-15, 07:53 AM
Lexi20081
Lexi20081's Avatar
Default Tried a few jumps... Didn't work.
Thanks for your reply. I tried a few jumps and it didn't work. Then tried to charge up the battery and it still didn't start. The battery is less than 2 years old and tested good so it's definitely not that. I wish it could have been that so it could be an easy fix.
But it sounds like it's trying to make a connection but something sounds broken/ it sounds like something is spinning fast which made me think it's the timing chain which still could possibly be and only a shop/dealership could determine that but I want to try to factor everything out before I tow it somewhere to get diagnosed. And it has crank and my gas tank has about a 1/4 tank left.
My car is a 2008 IS250 model with only 61k miles. It was in perfectly good condition before this happened.
Old 06-02-15, 08:54 AM
getafewliv
getafewliv's Avatar
I don't think I have heard of timing chains breaking very often (or at all?) on these cars and that seems like a pretty quick jump to conclusion.
Have you checked for engine codes?
Old 06-02-15, 12:42 PM
Gville350
Gville350's Avatar
If the timing chain broke, you would definitely know!
Did you say that with the current 2yr old battery that you can get the car to turn over, but not start? Air/spark/fuel, which are you missing?
Old 06-02-15, 02:10 PM
Haitwun
Haitwun's Avatar
Even if you think it is not the battery, it may be the battery. Jump start it and see if that works.
Old 06-02-15, 03:45 PM
getafewliv
getafewliv's Avatar
He said he tried that a few times.
Old 06-02-15, 06:21 PM
Lexi20081
Lexi20081's Avatar
Default Transponders
Everything just seems so odd. It went from running perfectly fine to sitting on the street, useless. Someone had mentioned the transponder/chip in my key and it disabling the car to start. I'll be using my spare key to try to start the car in a little bit to see if this is the problem.
Old 06-02-15, 06:26 PM
hirsch2is
hirsch2is's Avatar
you could have a starter that isn't ejecting its gear into the ring gear. i see this often on toyotas. transponder is also possible.
Old 06-03-15, 09:35 AM
getafewliv
getafewliv's Avatar
I don't think it's the starter if it is cranking over and I thought if the chip isn't present (or programmed correctly) the car would not crank at all.
Have you checked codes yet? Should be the first thing to check.
Old 06-03-15, 11:26 AM
hirsch2is
hirsch2is's Avatar
Well he mentioned it sounded like it was spinning faster that why j though starter
akafixture
03-12-17 02:23 PM
Kelsis300
IS - 1st Gen (2001-2005)
12-05-12 12:05 PM
koaishi
Maintenance
09-21-12 01:58 PM
tlegend
RX - 1st Gen (1999-2003)
01-20-08 06:36 PM
tmf2004
01-08-06 09:36 PM
Quick Reply: Help! Car won't start... Any ideas why?
