2008 is250 power steering swap
Old 05-15-15, 03:34 PM
SLvERis250
SLvERis250's Avatar
Default 2008 is250 power steering swap
is there anyone who has done a power steering conversion from the EPS system to a fluid system? are there any existing systems that can be implemented in the is 250. I just read the thread where someone is doing an LS 1 motor swap and he is using it from the existing ls1 power steering to be installed in the IS. Any systems that are easily compatible???
I just purchased an is250 and as I was driving it off the lot power steering failed on me. I bought the car with a rebuilt title but for the most part the car ran fine. As I am reading through some of the experiences some have had with PS failure I've become more concerned. I think I want to just go ahead and do the conversion and avoid having to deal with the ePS system altogether. Any advice will be greatly appreciated.
Old 05-15-15, 04:04 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
I feel a retrofitted HPS system will probably be less reliable than the stock EPS setup.
But maybe that's just me.
Not sure what components you'd use, but consider a PS pump from a Camry, or maybe possibly some Japanese xGR-F[S]E RWD setups, maybe from around 2003-2005'ish.
Jeff
Brayden
12-24-20 10:21 PM
AlexLexus8
07-31-17 08:00 AM
Bleak
Performance & Maintenance
07-22-13 09:07 PM
JimKing
03-20-11 11:36 PM
gtwill
12-19-10 04:07 PM
Quick Reply: 2008 is250 power steering swap
