3IS Style Tail Lights on 2IS
Old 07-27-15, 07:36 AM
  #31
heyarms
heyarms's Avatar
Originally Posted by dorkacho
so there are 3 different ones? 78work vs ebay vs nigel ? :O
I believe there are 4....
78Works (original ones to design them as far as i can tell, they were debuted almost a year ago)
Spec-D
Nigel (which i believe are produced by Office24)
and... tons of eBay ones.
Love my 78Works. Brought a much fresher look to the car.
Old 07-27-15, 10:54 AM
  #32
AlexiaMom
AlexiaMom's Avatar
Spec-D
The orange leds are okay... but yours with the white looks better
Old 07-27-15, 04:49 PM
  #33
dorkacho
dorkacho's Avatar
thanks for answering! those lights look great on your car!
is there any difference between spec-d and nigel? i've seen so many pics but cannot tell any major difference.
Old 07-27-15, 05:14 PM
  #34
Assailant
Assailant's Avatar
Hi, just wondering if you had any check vsc after you installed your taillights, I have 78 works and after I installed the lights I got vsc, abs, etc. Ran codes and I got code c1249. Thanks in advance!
Old 08-17-16, 11:20 PM
  #35
EagleEye7
EagleEye7's Avatar
Not to bring up an old thread, (I'm new here and I did search the forums) but I am currently experiencing the same thing when I installed my Nigel led tail lights as well. It was a plug and play harness with no resistors attached/included. But there is a random wire with a tiny connector attached to the reverse lights that has nothing to plug into. Due to that I just put in a couple 194 led bulbs as a substitute since I wouldn't have had any reverse lights. Once I started the car up I also got the dreaded dash lights.. check vsc, abs, traction, ebrake light, etc. Ran the code and it also came back as c1249. I've done some research about the code, but nothing that relates to led tail light install. I've disconnected the battery, reset the code, but it came back. Am I missing something? I'm taking my car into the dealership this weekend since my nav is miscalculating. Figured I'd also ask them about the code and see what fix they have. BUT, does anyone have a solution to this in advance?? Please help! Thanks!
Old 08-18-16, 04:50 AM
  #36
MAizz
MAizz's Avatar
I've had both Nigel's with LED back-ups and Spec-D, never had any codes pop up, good luck
Old 08-18-16, 05:46 PM
  #37
heyarms
heyarms's Avatar
Ive heard of a few people with CEL's from aftermarket tails and i can not for the life of me figure out what is going on with it. I haven't seen it in person just heard about it, so i can't help them diagnose in person. I have plugged in multiple sets of 78works on my car when i import them and my dash never lights up. All i can tell people is to ensure you have wired the resistor in properly and no fuses are blown. *shrug*
Old 08-18-16, 09:13 PM
  #38
EagleEye7
EagleEye7's Avatar
Right on guys, thanks for the replies. I've been messing with the wiring again but still no luck. I guess if I find the right diagnosis, I'll be sure to share.
Old 08-19-16, 08:52 PM
  #39
Assailant
Assailant's Avatar
Default How to remove the code
Hey, so I had the same issue(posted earlier in the thread) and I solved it last year. It depends where your car is from. Since my car is Canadian and the lights 78works (Japanese) the mechanic I found told me there are stict regulation here and cars here have to meet certain criteria for safety. The car LEDs caused the code C1249 to pop up cause it thinks that your bulb in the tail lights arent working. I'll try and explain what wrong the best it can and try and remember what the the mechanic said. Basically the problem is led light have pulsing wave while the regular light has a straight signal. From what I remember is my mechanic had to go to Lexus tech and ask for a diagram of how the light reacted with the computer and he wired the led lights (not sure what he used) to trick and the computer into thinking that they are bulb (oem) lights. It cost about $30, hopefully someone who knows more about these technical stuff can better explain this lol but I think this is what is happening. If you live in Toronto I can recommend the shop
Old 08-24-16, 06:12 AM
  #40
ponteley
ponteley's Avatar
I'm not sure why all of them are marketed as: "for 06-08 IS250/350"
Just installed Spec-D on my 2011 is350 - PnP, no modifications to anything, same harness, just follow included manual.
All good so far.
Old 08-26-16, 12:51 AM
  #41
Koolsport
Koolsport's Avatar
All good so far.
OK I took the plunge and I am trusting your say so....
I just ordered some from K2 on ebay for $350 and I also have a 2011 IS350 f sport...
Hate to find out I blew $350....lol
Old 08-26-16, 04:24 AM
  #42
MAizz
MAizz's Avatar
Originally Posted by Koolsport
OK I took the pluge and I am trusting your say so....
you didn't, thats who I bought mine from for my 2012, no flaws a year out
Old 08-26-16, 01:36 PM
  #43
shadowman
shadowman's Avatar
These look surprisingly good. I know what to get now if my OEM ones start burning out.
Old 08-26-16, 03:49 PM
  #44
Ktran1039
Ktran1039's Avatar
Mine are from Spec-D on a 2008 no real issues
Picture was taken with brake lights on.
Old 08-28-16, 10:36 AM
  #45
Koolsport
Koolsport's Avatar
Thanks appreciated the reassurance....that's good to hear...will try to post a pic when I get them installed.
Quick Reply: 3IS Style Tail Lights on 2IS
