100,000 mile servicing ?
I'm a little over 100,000 miles on my 08 IS250. I've been getting emails from the dealer about being due for my next servicing. Is there anything special at 100,000 miles that should/need be replaced or done ?
Thanks. I did change the cabin air filter myself last year. Can't recall if any of those other things were done. I'll make sure the dealer doesn't try to do anything that is not needed...
Start reading some of the old post here, https://www.clublexus.com/forums/is-...ml#post2446051
I have a toyota tacoma that has no dip stick and is also has a auto trans, but it can be easily flushed or just drained and refilled. The IS has no lines running to the radiator but you can drain 1.5 -2 quarts from the drain plug and use a hand pump to add new fluid back.
Threxx
Maintenance
02-18-03 06:50 PM
