Factory HID wiring diagram
I swear I searched for hours on this as I hate waiting for answers.
My ballast in the bottom of my passenger headlight is shot! The previous owner (a lady) was dishonest and must have had a fender bender at some point. I fixed the lower passenger foglight that needed to be resealed/repaired with water in it. Now weeks later, the headlight went out on passenger side. It's due to a half gallon of water (YES) that I drained out of the housing and resealed. Now that I put everything back together the HID system still does not work. I tried switching bulbs and both bulbs are fine.
Long story short I've decided I'm not taking the headlight back out to get to the factory ballast. I ordered an aftermarket LED system and want to wire it into the factory system. I need the wiring diagram that shows where the lowbeam pinout is at the factory headlight connector.
This will save me having call a friend and using a test light to see what wires are for the low beam. Please post the diagram or just tell me what wire color to tap for power and ground. if the ground comes from the chassis that's no big deal. I'll find an ideal spot.
Thanks guys!
Thanks guys!
Thank you Jeff!
I don't recall seeing numbers on the connector but with this diagram I assume this must be the case. If not do you have wire color information?
CAN-Other ISO : passenger side hid afs headlight
InfamousF
12-04-16 07:45 PM
