Looking at an IS 250, looks like the carbon recall was done, does this look good?
Old 02-01-15, 09:13 PM
MikeZero
MikeZero's Avatar
Default Looking at an IS 250, looks like the carbon recall was done, does this look good?
This work was done at 57500 miles and the car now has 57550 miles on it, so they literally JUST did the work. Good thing? Great thing? Or worrisome thing? Isnt that a little bit low of miles for the carbon issue to happen? I thought it was usually closer to 100k.
PERFORMED ZLA, REPLACED ENGINE PISTONS, PISTON RINGS, CLEAN CARBON FROM VALVES - CUSTOMER STATES VEHICLE MISFIRES AT IDLE OR AT INITIAL START UP, ENGINE SHAKES VEHICLE RUNS ROUGH , D.S TO INSPECT & ADVISE - PERFORM ZLA TAS CASE 150120509 - EXCESS CARBON IN VALVETRAIN CAUSING INTM. MISFIRE TYPE CONDITION,ZLA TAS CASE 150120509 - PERFORMED ZLA, REPLACED ENGINE PISTONS, PISTON RINGS, CLEAN CARBON FROM VALVES, RE - ASSEMBLED ENGINE,ROAD TEST
Old 02-02-15, 01:03 AM
liqB
liqB's Avatar
It seems that carbon buildup could happen at any mileage.
Old 02-02-15, 01:12 AM
Meguerra
Meguerra's Avatar
My 2008 IS 250 had the rebuild done at 50,782 miles. I bought it with 52,556 a couple of months after the rebuild. It has run strong and has had great gas mileage since I have owned it. It's a great car and I am really happy with it.
Old 02-02-15, 04:15 PM
Gville350
Gville350's Avatar
The carbon build-up heavily relies on the fuel used and the previous owners driving style. Slow inner-city driving will more quickly build-up carbon deposits than those that beat on their with many WOT pulls and HWY miles. FULL heat cycles also help with issue.
Lexus warranties this motor work; so I'd not worry about it.
Old 01-10-16, 06:20 AM
cheerio3
cheerio3's Avatar
I recently bought an 06 IS 250 that had the ZLA recall performed. I am unclear on the carbon build-up issues. Once the ZLA recall is done to replace pistons/seals is it a one-time fix for the carbon build-up? Or is carbon likely to reaccumulate over time and require more service in future?
2Insane
RC F (2015-present)
20
04-18-20 11:31 AM
NYKnick101
10-13-15 07:39 PM
skyhigh23
10-21-13 12:19 PM
SpmMorrow
IS F (2008-2014)
40
02-13-13 09:17 PM
RobzKar
02-16-10 04:15 PM
Quick Reply: Looking at an IS 250, looks like the carbon recall was done, does this look good?
