IS350 Condensation in headlight
Old 01-19-15, 11:03 AM
tarzan350
tarzan350's Avatar
Red face IS350 Condensation in headlight
so my bulbs went on me last week, ordered a new set of hid bulbs morimoto 5k bulbs. before replacing my bulbs used to flicker on and off. I would just turn on and off head lights then they would work until one day they just completely stopped working. driver side headlight does have a bit of condensation in the headlight assembly and thats the headlight that does not work at all. i switched bulbs with the passenger side but still does not work. Passenger side works fine. You think it can be a bad ballast? Is there a way i can check the ballast with a volt meter, and is it worth replacing the ballast or finding a used headlamp on line since this one has condensation in it? Thanks any information is appreciated!
-2008 Is350, 54k miles
Old 01-19-15, 03:00 PM
toyoman29
toyoman29's Avatar
I would find a good used OEM pair or just the drivers side head light because you have a crack or broken seal in the old light and the bulbs won't last, you could check the voltage on the pass. side and then the drivers to compare but i would replace the headlight first and go from there. Welcome to CL....
Old 01-20-15, 10:56 AM
LucianoLee
LucianoLee's Avatar
You already confirm the problem was the ballast after switching the bulbs. Just get another ballast and change it ur self. There is a video on youtube shows how to do it. But you'll have to take off the bumper tho....
Old 04-06-15, 09:14 AM
mandyfig
mandyfig's Avatar
Where do we get the ballasts?
Old 04-06-15, 09:25 AM
Zfrog
Zfrog's Avatar
eBay
merkin110
01-05-16 05:04 PM
liujiayue
05-18-15 06:34 AM
RAY1983RAY
05-02-13 08:49 AM
emery65038
11-16-11 11:47 AM
Quick Reply: IS350 Condensation in headlight
