i have a 07 IS250. It started up for 5 sec, then died. Said "Check VSC" I thought it might be the battery and had it replaced, but still would not start. So i searched around and hope it maybe a bad fuse. Maybe something to do with the fuel pump. So I was attempting to pull out the large green fuse in the second picture (fuel pump fuse i think). Also will try to see if the main fuse is blown. It's in there pretty good but before i try to yank on it I was hoping to see if anyone here had experience pulling one of these.
Next up is to borrow my friend's ODBII scanner and see if it threw a code.
