Clunking sound from passenger rear - HELP
Old 12-11-14, 08:48 PM
Nixcision
Nixcision's Avatar
Angry Clunking sound from passenger rear - HELP
STORY:
So I was coming home from the library the other day, stressed out about exams and what not, and thought I'd have a little fun with my 250...
Long story short, Theres this dip (looks like a big depression in the road) in the far right lane, which I'm coming down, and right before I was on top of it, I cut left quick enough for most of my car to miss the dip... unfortunately, my passenger rear wheel when into it and made a tiny sound coming out of it..
I didn't think much of it so I slowed TF down and calmly carried on home...
PROBLEM:
2 days later (today): I'm getting this random clunking noise from that side...
If anyone has ever grabbed the bottom of their license plate cover and pulled it and let it go and it makes a rattle sound, thats what it sounds like... theres no squeaky sounds so i don't think its the shock.
I used to get the same sound ONLY when i drove over a railroad crossing, but now it makes it on the main streets!
Its random as well... on some bumps it makes sounds, on some it does not..
Anyone have any idea what this is? I will try and get it on a lift this weekend if possible..
Old 12-11-14, 08:57 PM
vietboy1st
vietboy1st's Avatar
bring it to the dealer to find out.. Don't guess.
Old 12-11-14, 09:41 PM
idoke1
idoke1's Avatar
Check your exhaust. The rubber piece that holds it up might had come loose and cause that sound you are describing.
Old 12-11-14, 09:43 PM
Nixcision
Nixcision's Avatar
hmm interesting... It can be heard when my window is open as well while driving (its loud enough).. i'll check the exhaust, but i didn't see anything hanging down when i briefly looked under my car!
Old 12-12-14, 12:39 PM
Gville350
Gville350's Avatar
Check your sway bar end links for proper torque. Do you have spring or coilovers?
Old 12-12-14, 01:03 PM
CARspec
CARspec's Avatar
This guy has the right idea. Have a shop look at it. The internet can't look at your car.
Old 12-12-14, 01:52 PM
Nixcision
Nixcision's Avatar
its gone away now... was just looking for opinions.
will get it to a shop in a few days
Old 01-06-15, 09:10 AM
lubolink
lubolink's Avatar
Default Clunking sound from rear of es series
This could be your problem, in fact almost all es300's around 2000 have this noise. The culprit is worn rubber bushings at the ends of the sway bar. In your case, you may have bent the sway bar by hitting a hole at high speed. Anyway, I just replaced my sway bar bushings with great success.
The best replacements are made by MOOG. A pair is under 20.00. You need two floor jacks, one to raise the rear of the car up enough to comfortably fit and see the bolts you need to remove.(the rear wheels do not need to be removed). there are two 10mm bolts per side. The bushing is split, for easy installation. Just open it up and pop it on. You will need a block of wood about 6.5 in. long to keep the sway bar up near its regular position after the bolts are removed. This is of course the reason for the second floor jack.
Old 01-06-15, 03:26 PM
Nixcision
Nixcision's Avatar
the sound seems to have gone away.. haven't heard it for the last few weeks!
alexkidd
01-21-18 07:53 PM
BinaryJay
11-04-15 08:53 AM
SteveLNJ
11-06-13 02:29 PM
xinvazn
IS - 1st Gen (2001-2005)
02-05-08 09:07 PM
jasonviper
04-08-07 04:27 PM
Quick Reply: Clunking sound from passenger rear - HELP
