QUESTIONS for my lexus/Toyota techs
Sorry if I'm posting this in the wrong section. 1st question ,Does anyone know if the is250 heads mate to the is350 block? 2nd question ,does the is350 motor bolt up to is250 6spd manual? Thanks in advance!
The 2GR motor does bolt up to the 250's 6speed but will take some wiring to get everything working properly.
As for the heads, someone correct me if I am wrong but I think they are the same so it should bolt up. If you scout some of the MR2 and celica forums, you will find alot more info about what can swap into/onto what block. I recently read that someone was swapping Camry 2GR-FE internals in to an FSE to boost a little better
