What the hell is this?
Old 08-21-14, 12:15 PM
sparta3993
sparta3993's Avatar
Default What the hell is this?
2006 IS250 with ML unit..
what the hell is this? bought it used but I got no clue what the hell this dial does... is that a telephone cord? ethernet?
Attached Thumbnails What the hell is this?-img_0230.jpg   What the hell is this?-img_0233.jpg   What the hell is this?-img_0232.jpg   What the hell is this?-img_0231.jpg
Old 08-21-14, 12:18 PM
Gville350
Gville350's Avatar
Similar to an ethernet cable, but I believe it was a gain control **** used for an aftermarket sub amp.
Old 08-21-14, 12:19 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,128 Likes on 1,298 Posts
Looks like a bass control ****. Is there / was there a sub in the car?
Old 08-21-14, 04:39 PM
Sffd103
Fire Slayer
Sffd103's Avatar
It is what has been said. That's where I had mine installed as well as a few other things (puddle lights, headrest monitors, led lights in subwoofer box.
Old 08-21-14, 04:45 PM
A1cntrler
A1cntrler's Avatar
Yes, as stated above it looks like a remote gain control **** for an aftermarket sub-woofer. My Infinity Basslink I had in my 300M Special had one with the sub but I didn't hook it up. I think maybe even some aftermarket amps can use them too. I bet if you trace the wire the other end is dangling in the trunk somewhere...
Old 08-21-14, 05:00 PM
dfwjohnd
dfwjohnd's Avatar
nawzzzzzzzzzz
Old 08-22-14, 09:58 AM
FSportIS
FSportIS's Avatar
It is probably the Bass Control **** that is connecting to the JL Audio amplifier. It looks almost exactly the same like mine because I have it in my car
Old 08-22-14, 04:33 PM
getafewliv
getafewliv's Avatar
Your **** is identical to mine and in the exact same spot :P
Old 08-22-14, 04:50 PM
sr20mofo
sr20mofo's Avatar
its a manual turbo boost controller
Old 08-23-14, 06:13 AM
s6 4rings
s6 4rings's Avatar
I recognize that ****... It's from a Valentine One.
Old 08-24-14, 10:17 PM
sparta3993
sparta3993's Avatar
So these were in the back. I know the amp is stock... I think... so Im assuming its plug and play now since it seems like it was already set up.. But this car came with ML and a sub already why another?
Attached Thumbnails What the hell is this?-img_0276.jpg   What the hell is this?-img_0277.jpg   What the hell is this?-img_0278.jpg
Old 08-25-14, 07:54 AM
Jaytea
Jaytea's Avatar
Probably a mono channel amp for subs in the rear. The stock amp for the rest of the speakers.
Old 08-25-14, 09:24 AM
bajandrift
bajandrift's Avatar
that unit in your hand is a low level converter most likely tapped into the ML amp connection(you can actually see where its tapped in the picture of the amp, its all covered with black tape, the ml amp has a small bass sub in the rear but some people (like me!) like a more deeper thumping bass so you can run an aftermarket amp and sub together with the ML unit.
that other bit is the bass control/level ***. pretty lucky the previous owner left this all in the car!!! you can leave it as its harmless or you can remove the lot, up to u!
Old 08-25-14, 09:40 AM
aznKewlguy
aznKewlguy's Avatar
Check the battery to see if there is a power wire coming to the back of your car. If there is one it will be plug in and play if you pick up a sub and amp.
Old 08-25-14, 12:26 PM
Gville350
Gville350's Avatar
Looks like the connections to the factory wiring look pretty good actually; I'd keep that converter in there just in case down the road you'd like more thump! I'd use some electrical tape to cover those inputs on the box though, just so it doesn't come into contact with any metal and cause distortion.
Quick Reply: What the hell is this?
