2011 IS Oil Change - Oil Pan Bolt Leaking
Old 08-19-14, 07:36 PM
nfordhk
nfordhk's Avatar
Default 2011 IS Oil Change - Oil Pan Bolt Leaking
Hi,
I've done countless oil changes but today was my first for my IS350. It's been a nightmare, first when I was done I put the o-ring in the wrong place for the filter and oil exploded everywhere. I bought a new filter put it on, started it seemed fine.
Now it appears its leaking from the oil pan plug. It's just a bolt, I don't see any washer or o-ring, is there suppose to be one? I know I had a tad too much oil in my car and am draining it of the excess but it's not a lot.
Seems to only leak when I drive.
Old 08-19-14, 08:02 PM
sjgIS350
sjgIS350's Avatar
"countless oil changes" and you don't know what a drain plug gasket is and you put the o ring in the wrong spot (hint it goes where the old one was)
Old 08-19-14, 09:33 PM
NikonGuy
NikonGuy's Avatar
That's why I use a Fumoto qwik valve. No more messing with drain plug. No more tools. And no more mess or leaks
Old 08-20-14, 09:30 AM
skottydznt
skottydznt's Avatar
theres an oil drain plug gasket that goes around the drain bolt. CHANGE IT EVERY OIL CHANGE ON EVERY CAR
Old 08-20-14, 10:24 AM
shadowman
shadowman's Avatar
Make sure that there is only one gasket on the drain plug. If they get stacked, it may also cause leaks.
My last oil change, I had forgotten about gasket that got seized onto the oil pan... I put the gasket back onto the oil drain bolt. I ended up with stacking up the gaskets. I only found out after my most recent oil change that I goofed.
Luckily I didn't have any leaks... Sometime the gasket end stuck together or at the pan and you think it fell off into the drain bucket.
Old 08-20-14, 11:01 AM
dstun
dstun's Avatar
Originally Posted by nfordhk
Hi,
there are numerous DYI write-ups and videos on this. Next time i would suggest brushing up on your oil change technique as every car is different.
but as others have said there's a crush washer (usually sold separate from the filter kit) you need replace each oil change.
Old 08-20-14, 12:16 PM
Gville350
Gville350's Avatar
At my local Lexus dealer, they toss in a coated crush washer into each oil filter you purchase.
So yeah, you need a washer in there!
GSLexTexas
01-17-17 09:20 PM
pauloil
06-21-13 08:09 PM
jeff1941
Maintenance
05-15-08 07:03 PM
Grumpa72
RX - 1st Gen (1999-2003)
01-28-06 05:59 PM
Quick Reply: 2011 IS Oil Change - Oil Pan Bolt Leaking
