Strong Gas smell in cabin & I've searched - Club Lexus Forums
Thread Tools Search this Thread
Old 07-22-14, 03:26 AM   #1
LexusGuyyy
Default Strong Gas smell in cabin & I've searched
The car has been sitting for quite some time, probably 3 months, and I've searched and went over what some key points to look for I cannot find a visual of gasoline anywhere. I've taken the car in for the fuel sensor gasket recall and looked to see if I had a leaking injector o - ring, the smell is too strong to even attempt to drive, any inputs?
LexusGuyyy is offline   Reply With Quote
Old 07-22-14, 07:00 AM   #2
idoke1
idoke1's Avatar
What year and model is it? What are the mileage on the vehicle? I remember another member having a similar issue but the smell was coming from his engine compartment.
idoke1 is offline   Reply With Quote
Old 07-22-14, 08:41 AM   #3
andy350
andy350's Avatar
my gas smell was coming from engine area and into the car.
so i took it to Lexus and this is what they changed and charged:
77251-53060 tube, fuel main - $57.85
23902-31012 tube sub-assy, fuel - $145.90
Labor - $410.80
Total charge with taxes - $641.99
it's fixed...no more gas smell
andy350 is offline   Reply With Quote
Old 08-13-14, 09:00 PM   #4
LexusGuyyy
Thanks for the heads up, I ended up taking to the dealer and paid a fortune, ended being some sort of gasket, i have to find the receipt again and viola no more smell !
Old 08-13-14, 11:49 PM   #5
jdmSW20
jdmSW20's Avatar
yeah my car does the same thing from time to time. i took it to the dealership and they couldnt figure it out either
jdmSW20 is offline   Reply With Quote
Old 08-14-14, 12:35 PM   #6
RangerJoe
I had this happen a few months ago. Took it to a local shop, and they said gas was leaking from the tube that feeds fuel from the drivers side of the engine to the passenger side. The dealer had removed the motor not too long before to fix a leaking timing chain gasket. I brought it back to the dealer and they fixed it for free, since the leak was caused by a bad gasket that they had messed with when they pulled the motor.
There are other things that can cause fuel leaks, but if you've had any work done where the motor was pulled (which I'm told dealers often do) it's something to think about.
RangerJoe is offline   Reply With Quote
Old 08-14-14, 12:41 PM   #7
Gville350
Gville350's Avatar
^Any paperwork given to you stating the item or part # of what was replaced in your case?
Gville350 is offline   Reply With Quote
Old 08-14-14, 02:39 PM   #8
toyoman29
toyoman29's Avatar
Hey guys, I have 2010 IS250 59000 miles and have a gas smell that started today after it had been sitting for three days, the smell seems to go away after a few miles down the road. The smell is just inside the car, no smell under the hood or no leaks on the garage floor, any ideas? Thanks in advance.
toyoman29 is offline   Reply With Quote
Old 08-14-14, 06:28 PM   #9
Gville350
Gville350's Avatar
If you continue to have this smell, I'd park it until you have a fix for it. From the few threads like this I've read, there have been fuel lines from the tank replaced and lines in the engine bay replaced. Of course you have different seals and gaskets that could go bad over time too.
GL on locating the leak!
Old 08-17-14, 01:05 PM   #10
toyoman29
toyoman29's Avatar
I think i figured out the gas smell on mine, my wife had just filled the car up with gas the day before we started smelling it inside, I think she over filled it and some gas from the over fill tube leaked out and the smell got inside the car. I drove it this week end and smell is gone, i told her after the first click when at the pump stop and don't add anymore.
Thread Thread Starter Forum Replies Last Post
Burning smell Boomin GS - 4th Gen (2013-present) 8 11-16-15 01:13 PM
interior detailing Cander Automotive Care & Detailing 1 08-31-15 10:32 AM
Fuel smell?!?!? Dwillard90 IS - 1st Gen (2001-2005) 0 11-03-14 04:59 AM
01 is300 fuel smell?!?!? Dwillard90 IS - 1st Gen (2001-2005) 3 11-02-14 04:00 PM
Burning brakes? nixx621 IS - 2nd Gen (2006-2013) 5 04-08-11 04:16 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
  • Ask a Question
    Get answers from community experts
What's your question?
Send
