So I took my car in for a smog check and......
Old 07-07-14, 11:24 PM
idoke1
idoke1's Avatar
Default So I took my car in for a smog check and......
Found out my car weights 4,000 lbs. That is just the car. My car is basically stock with intake and exhaust. I did however had a full tank of gas but @ 4,000lbs..... makes me wonder if I can shave off 1,000 lbs....how much quicker would I be at the 1/4 mile?
Edit: Here is the test result and for some reason, its flipped?
Attached Thumbnails So I took my car in for a smog check and......-20140708_234359.jpg
Old 07-08-14, 12:37 AM
Sffd103
Fire Slayer
Sffd103's Avatar
I highly doubt 1000lbs can be take off. You wouldn't fly, let's just put it that way.
Old 07-08-14, 01:05 AM
metaleckz
metaleckz's Avatar
So did you pass or not
Old 07-08-14, 08:03 AM
idoke1
idoke1's Avatar
Yes I pass. I pass without my secondary cats too. Thats because the mechanic didn't even look underneath the car. He saw my primary cats and probably assume that was it.
Old 07-08-14, 03:54 PM
chi123
chi123's Avatar
Your IS350 weighs 4,000 pounds!? Mine weighed in at 3580 and that's with two subs, a trunk full of stuff, and half a tank of gas.
Old 07-08-14, 04:32 PM
Gville350
Gville350's Avatar
Yeah, sounds like something is not calibrated correctly. One gallon of gas is only 6lbs.
Old 07-08-14, 04:41 PM
FSportIS
FSportIS's Avatar
Mine weight around 3600 pounds. Where is the extra 400 pounds fat comes from??
Old 07-08-14, 11:36 PM
idoke1
idoke1's Avatar
^^I don't know but when I find my smog papers, I'll post up the info. I remember reading curb weight: 4000lbs.....and I was like Huh?
Old 07-08-14, 11:54 PM
604GSE21
604GSE21's Avatar
throw out those comfy power leather seats probably will save u a bunch, loose the spare, take out sound system, took kit...
Old 07-09-14, 12:43 AM
metaleckz
metaleckz's Avatar
might as well remove the engine, tranny, chassis, wheels and tires... those are pretty heavy
Old 07-09-14, 08:25 AM
WylieKylie
WylieKylie's Avatar
Your car doesn't weigh 4,000lbs. They typed in 4000 cuz it was easy and it sounded like a good number to the guy who filled out the form. They also put that your car has a single exhaust when clearly there is more than one pipe coming out the rear of the car.
Old 07-09-14, 08:29 AM
Sportskid1
Sportskid1's Avatar
Was the guy doing the smog check 400lbs and sitting in the car when he weighed it?
Old 07-09-14, 09:19 AM
idoke1
idoke1's Avatar
^^lol. I don't think a 400lb person will even fit in the driver side seat. I'll go back and talk to him sometime later to see if I can have a retest on the curb weight of the car.
Old 07-09-14, 09:47 AM
kickin8
2IS/2RX/4RX
kickin8's Avatar
oh wait...it said SINGLE exhaust????
Old 07-09-14, 09:49 AM
azfsprt
azfsprt's Avatar
He rounded it off, obviously he was too lazy to see your 2ndary cats so ya..
Your car should be around the 3600lbs area. As for reducing 1000lbs, good luck! maybe we will see you fly!? LOL
Quick Reply: So I took my car in for a smog check and......
