So I took my 350 on a canyon-type road today
Old 07-11-14, 09:31 AM
  #91
Re3iRtH
Re3iRtH's Avatar
FIGS? please elaborate
Originally Posted by WylieKylie
You've mentioned that the 350 is already much faster than the S2000 in a straight line, I'd continue modding the suspension before going after more power. Here is what I would do:
Sticky tires
FIGS front LCA bushings
'11+ IS F Steering ECU
Oh wait... that is what I have done and/or plan on doing
Old 07-11-14, 11:05 AM
  #92
WylieKylie
WylieKylie's Avatar
These cars have big, soft bushings on the back end of the front lower control arm. These soft bushings make the toe change dynamically (especially when you hit the brakes and turn at the same time). The result of this is that the steering precision is reduced and the inside edges of the front tires wear out prematurely. Replacing the bushings with FIGS/Superpro bushings reduces these issues. There is absolutely no downside to this mod, other than the cost.
http://shopfigs.com/v1/index.php?rou...product_id=138
http://shopfigs.com/v1/index.php?rou...product_id=235
^ both the same item, but they are much easier to install if you buy them pre-installed in the brackets
More info:
https://www.clublexus.com/forums/is-...eo-inside.html
https://www.clublexus.com/forums/sus...0-duro-hp.html
Here are pictures during and after install:
Old 07-11-14, 12:26 PM
  #93
Re3iRtH
Re3iRtH's Avatar
Muchos gracias!
But $360.. Ouch. Any other option like do they go on sale or
another manufacturer?
More info:
Old 07-11-14, 01:44 PM
  #94
WylieKylie
WylieKylie's Avatar
Muchos gracias!
Unfortunately there isn't another option. The "regulars" like Energy Suspension and Prothane don't make a thing for the 2IS. FIGS sources these bushings from Superpro, which is based in Aurstralia.
$360 is for new brackets, going with used brackets knocks $15 off the price, and you will get $60 back when you return your old brackets. I looked at it this way: the $300 I spent is expensive, but if I wear out two sets of front tires in 1/2 as many miles as they should last (which is not uncommon on a 2IS), that would have paid for the bushings.
Old 07-11-14, 02:18 PM
  #95
Re3iRtH
Re3iRtH's Avatar
Is that a common thing to wear tires 2x as fast with the
OEM bushings?
I mean during regular driving. Do you autoX that's why..
Old 07-11-14, 02:21 PM
  #96
Re3iRtH
Re3iRtH's Avatar
According to those links, its $150 off if you use the OEM brackets,
not $15
Old 07-12-14, 01:42 PM
  #97
WylieKylie
WylieKylie's Avatar
not $15
$360 is the cost for bushings pressed in to new OEM brackets
$345 is the cost for bushings pressed in to used OEM brackets
With either of these two options you get $60 back when you return your old brackets to FIGS.
$210 is the price for just the bushings, this way you have to find a shop to press the bushings into your brackets, which has been challenging for some people, and also creates more downtime.
Old 07-12-14, 11:37 PM
  #98
mrAkana
mrAkana's Avatar
Well, at least I have direction as to what I need/want to mod next. This is definitely one of the more informative threads I've read yet, good luck OP and thanks CL!
Old 07-21-14, 10:27 AM
  #99
WylieKylie
WylieKylie's Avatar
OEM bushings?
Slow reply, I missed this.
Yes, regular driving wears out the inside edge on a 2IS. Check random cars in a parking lot. Chances are the inside edges will be much more worn than the outside. Or check and see if the front tire brand/model matches the rear, the majority of owners are going to throw the cheapest crap rubber they can find on the front of the car when they see cords on the front inside.
Old 07-21-14, 10:43 AM
  #100
lexicanto
lexicanto's Avatar
Recently drove this. Excellent car. Loved it. I wish the price was a little more affordable. But a great car for its demographic.
Old 07-21-14, 12:41 PM
  #101
Re3iRtH
Re3iRtH's Avatar
What are you referring to here.. an IS350 with the aforementioned bushings installed?
Aspect
Suspension and Brakes
09-28-16 01:07 PM
blklexo818
32
10-20-11 04:29 AM
kayotik
16
07-07-09 02:00 PM
love67
33
02-12-09 02:43 AM
ndk83
13
01-03-08 09:47 AM
Quick Reply: So I took my 350 on a canyon-type road today
