Intermittent Start
Old 06-25-14, 12:09 PM
Blue250
Blue250's Avatar
Default Intermittent Start
Been having some intermittent start issues with my 2007 is250.
Every third or fourth start the engine cranks with no start. Sometimes 3 tries to get it to fire.
Previous owner had the carbon build up issue resolved .
Vehicle has had all the schedule service done through the dealer and only has 53000 miles on it.
Any ideas on what this might be?
Old 06-25-14, 12:38 PM
idoke1
idoke1's Avatar
Check the ecu for any stored codes. Also check for any loose wire connections. Especially the ground wiring.
Old 06-25-14, 01:23 PM
kickin8
2IS/2RX/4RX
kickin8's Avatar
check the battery first....
Old 06-25-14, 05:54 PM
NYKnick101
NYKnick101's Avatar
low battery voltage could be the issue. Is it the original battery that came with the car. With most cars, the battery provides starting power and once the car is started, it switches over to the alternator to provide power
Old 06-27-14, 11:42 AM
Blue250
Blue250's Avatar
Are we talking battery volts or checking battery contacts? (ground)
Old 06-27-14, 12:38 PM
MEAHT
MEAHT's Avatar
I think Knick is saying you might need a new battery. Same thing happened to about 6 months ago. When I started the car, it wouldnt instantly turn on, sounded like it was struggling.
Seems my OEM battery was done for.
Picked up a new battery and the car started faster than ever.
Old 06-27-14, 01:27 PM
NYKnick101
NYKnick101's Avatar
YES!! you may need a new battery! If you are able to, take it out and take it to the autostore to get tested.
Old 06-29-14, 05:59 AM
Blue250
Blue250's Avatar
Thanks for all of your help. It has been starting fine for the last week. If it happens again I will pull the battery and get it checked.
Old 06-29-14, 06:28 AM
Bichon
Super Moderator
Bichon's Avatar
No need to pull the battery to get it checked. Any Autozone or Advanced Auto Parts store should be able to test your battery in place (for free) and tell you if it is good.
Old 06-30-14, 06:49 AM
Blue250
Blue250's Avatar
Thanks for the tip. I will have them both checked.
Old 06-30-14, 07:41 AM
embolism
embolism's Avatar
I'm still on my original battery too (2007). Did you know that to get the exact OEM Panasonic battery from Japan is $1400? Anyhoo, mine failed to start on the first try about a year ago so I started doing some research.
Turns out our original batteries use distilled water in the cells. There are 6 star shaped plastic ***** on the battery that you should be able to twist open and unscrew by hand. if they look low, just fill them up with DISTILLED water, replace the caps and you're done.
I tested my battery before the winter of the year I refilled it, and it still had about 520 CCA left (I think original spec is 575 CCA). Haven't had another start issue since I filled it but I will check it before each winter now and expect I will have to change it either this year or next.
Old 07-02-14, 09:40 PM
istarzan
istarzan's Avatar
Ah! I have an 07 is350 still with original battery too. I left the lights on for too long without engine running and had to have it jumpstarted twice. Been looking for a replacement but holding back because honestly I don't like how the aftermarket batteries look lol. So I can just add water to it and it'll be fine?
Old 07-04-14, 07:47 AM
embolism
embolism's Avatar
Couldn't hurt, but don't just add water, that is sure to kill the battery.
You need to use DISTILLED water, not spring water, not evian water, it must be distilled.
akafixture
03-12-17 02:23 PM
c8545
06-01-16 01:47 PM
beverlybee
10-07-13 07:43 PM
koaishi
Maintenance
09-21-12 01:58 PM
kqt2ktval
12-12-06 07:42 AM
Quick Reply: Intermittent Start
