CE light P0441
CE light P0441
hey guys yesterday when i was driving about 30mph my CE light came on pulled the code and code is p0441, i did fill up that day and sadly yes i overfill my tank to the top where you could even see the gas, my 1st time in this car that i did that, any tip out there here is what the code means, has this happen to anyone else?
Symptoms
Check Engine Light will illuminate
In most cases, there are no adverse conditions noticed by the driver
In some cases, there may be a noticeable fuel odor caused by the release of fuel vapors
In some cases, the engine may idle rough, hesitate or stall
Common Problems That Trigger the P0441 Code
Missing fuel cap
Stuck open or closed purge valve
Defective or damaged fuel cap
Distorted, damaged or cracked Fuel Tank Filler Neck
Torn or punctured Evaporative system hose(s)
Defective Fuel Tank Sending Unit gasket or seal
Split or damaged Carbon Canister
Defective Evaporative Vent Valve
Defective or damaged fuel tank
Common Misdiagnoses
Fuel cap
Evaporative Purge Valve
Symptoms
Missing fuel cap
Common Misdiagnoses
Fuel cap
since i got no helped here i end up taking car to dealer to get it fix, my total charge for the fix was $0 turned out the Purge Valve connector was disconnected -____-
Oro
05-19-17 04:08 PM
Patrickleo
06-27-16 09:42 AM
