So what's the consensus on Linea wheels?
Old 06-20-14, 02:42 PM
  #61
FSportIS
FSportIS's Avatar
The weight saving from having lightweight wheel is UNSPRUNG WEIGHT which is different from the regular weight on the car. The less unsprung weight, the less ROTATIONAL force needed to move the wheels/tires which give traction to bring the car forward. Since less rotational force is needed, it requires less power or torque to move. Hence, it gives the following benefits:
1. Smoother and slightly faster acceleration.
2. Smoother and shorter stopping distance.
3. Better fuel economy.
Now that is the theory. In reality, I can confirm this as well through my own experience. I also want to add smoother and more accurate steering feel as well.
I believe someone have done an experiment and document it here http://www.carcraft.com/projectbuild...ls_comparison/
What is unsprung weight? https://answers.yahoo.com/question/i...=1006012500665
Originally Posted by Batistuta
What is the significance of shaving 20-30lbs off the wheels on a almost 4000lb car? Not trying to start an argument, I really want to know.
Old 06-20-14, 04:12 PM
  #62
WheelDude.com
Former Sponsor
WheelDude.com's Avatar
Sounds like if a wheel cracked, I'd be SOL but my main concern are reports that I would not be able to purchase a replacement wheel, is that true? You only sell them by the set?
We sell replacement wheels, it's not a problem, as long as we have it in stock we will sell it.
As far as cracked wheels, most of them are covered under warranty, even if we see signs of slight impact.
Remember, it's not a forged wheel, so at a hard impact, the wheels tend to get a hairline crack on the inside barrel rather than bending
This is the case with a lot of OEM BMW wheels and many other cast wheel manufactures as well.
We just happen to cover this most the time
It's at our discretion of course, but most the time it's covered unless it seems like a major impact.
Old 06-20-14, 05:41 PM
  #63
metaleckz
metaleckz's Avatar
Originally Posted by MarioIS
thanks for your input metaleckz.
Doubt theyll have 18x8.5 but hope theyll do. It looks like a nice wheel. Wish i can run 19s.
But road conditions here are horrible
I have the perfect rims for you! Check miro wheels type 398. The one that looks like the te37. They have 18 with mild width
aggatek
02-03-12 04:04 PM
RacerLex
Wheels, Tires & Brakes Forum
39
03-29-07 06:40 AM
LexFather
06-09-05 05:30 PM
engin_ear
12-15-04 05:46 AM
tommie
15
02-09-03 08:27 AM
Quick Reply: So what's the consensus on Linea wheels?
