I need help on wiring? :(
Old 05-18-14, 03:03 PM
metaleckz
metaleckz's Avatar
Default I need help on wiring? :(
No ones helping me on this one thread so Im making one so everyone can see lol
I have is350 with Mark Levinson no navi.. now I want to add subwoofers. I already wired the power and ground wire.
So is this correct?
if not please enlighten me
Old 05-19-14, 12:22 PM
metaleckz
metaleckz's Avatar
Bump!
How do I add subs? Where do I connect to get signal from LOC?
Old 05-19-14, 12:26 PM
goukie
goukie's Avatar
I should be able to take a look at mine later today but mine might be different but once you see it you should be able to get the idea.
Old 05-19-14, 02:34 PM
kumquatism
kumquatism's Avatar
I don't know if your wires are correct, as I never dealt with ML before. You'll get signal from the RCA outputs. Turn switch to line out to get signal to RCA plugs. Plug RCA into amp and amp to sub. Good luck Kevin
Old 05-19-14, 03:17 PM
metaleckz
metaleckz's Avatar
Thanks !
Old 05-19-14, 03:18 PM
metaleckz
metaleckz's Avatar
Im not sure about the wires lol im still waiting for my subwoofer but I already have my amp. I wanna wire it now so by the time my subs get herr itll jusg be plug and play
Old 05-20-14, 11:27 AM
metaleckz
metaleckz's Avatar
Bumppppppp
Old 05-21-14, 10:51 AM
metaleckz
metaleckz's Avatar
Another bump!
Old 05-22-14, 11:07 PM
metaleckz
metaleckz's Avatar
Helpppppppp
Old 05-25-14, 12:00 AM
marcsis250
marcsis250's Avatar
first of all, no I believe that will not work, heres why, the ML amp actually crosses over the frequencies internally for the speakers, so it looks like you are trying to take signal from the front speaker and one of the rears. cant tell by the picture. but you will not get the full frequency response for a full range signal like that.
keep it simple, go to the subwoofer that's mounted to your rear dash and pull the signal from there, just run the wires down to the level converter and then your done. the wires I believe are green and brown, its should be on the white plug, last two pins. if you don't have a volt meter to check continuity then just got to the sub and tap it at the plug in subwoofer. good luck.
also you don't need to use that level converter either, that's a four channel level converter. get the scoche two channel converter comes with turn on remote sensor.
this one is good cause you can feed power and ground, then it uses current sensing to feed 12v to your remote turn on on amp, it even comes with a bass **** incase your amp doesn't.
clov3r
11-19-19 05:47 AM
Amishmatt
01-25-18 03:04 PM
94slowbra
12-29-09 07:45 AM
VTLexus
10-19-08 02:01 PM
Quick Reply: I need help on wiring? :(
