Manual Transmission in 250 AWD
Does anyone know if the transfer case will bolt to the manual transmission and if the manual transmission is longer or shorter in length then the auto? Couldn't find any of this info when searching.
well we know the transfer case unbolts from the transmission. We dont know if it can be a direct bolt on to the 6 speed manual and I dont think anyone has actually tried
If you wanted the manual should of gotten in the first place. I beleieve transmission sit different from awd and RWD. If you look at your awd center console by your leg it wider there than in the RWD to fit the transmission . Hence why a lot of big owner complain about there legs hitting that area but not on RWD.
islove623
10-02-22 03:58 PM
