Need better handling! Help! IS250
Im going to be entering an autox event where there are sharp turns and corners. I have a 2006 is250 RWD and I already have H&R springs with spacers and just put on new tires. I'm trying to find a under $100 way to improve my handling a bit! I was thinking a front strut bar that goes under your hood? I read that getting new sway bar bushings help a bit? I don't really know which direction to take. Do you guys have any ideas on what I should do here? Thanks for the help!
Was lookin at this strut bar that goes under your hood any thoughts?
http://www.ebay.com/itm/Manzo-Front-Upper-Strut-Tower-Brace-Bar-Lexus-IS250-IS350-06-07-08-/111210780223?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3ALexus%7CModel%3AIS250&hash=item19e4add63f&vxp=mtr#ht_2468wt_1363
The IS doesn't use struts, so using a brace like this is not nearly as effective as on a car with struts. There is almost no lateral forces on the upper mounting points in a double wishbone setup, almost entirely vertical.
It would stiffen the body slightly I suppose, but if you want better handling, look into sway bars among other things first. Adding bracing would probably be one of the last things on your list.
Jeff
Jeff
Jeff
Jeff
Yes, Jeff is absolutely sure the car doesn't have struts. As are the rest of us who know the difference between a strut and a double wishbone (front) or multi link (rear) suspension.
Just because there is a place in the engine bay that the shocks mounts doesn't mean the car has struts.
Edit: D'oh! Jeff beat me to it.
But while I am editing you shouldn't spend a dime on anything to make your car "faster" for your first autocross.
